Fuel/Spark issues maybe?
Old Sep 13, 2009 | 05:49 PM
rj95lss's Avatar
Question
Originally Posted by Disco Mike
The 159 fault is an 02 sensor slow to respond, bank 2 sensor 2.
With your mileage, replace all 4 02's. since both banks 2 02's are acting up. it is safe to say that replacing the 02's will correct the misfire and lean issues.
Ohh my god Mike that is what I wanted to hear. Thank you soooooooo much.
So I put new plugs in a had the codes read this morning and only these three came up this time and I was about to buy 2 o2 sensors for the 2 on bank 2.
P0174 = System Too Lean
P0150 = o2 sensor circuit malfunction (bank2 sensor1)
P0159 = o2 sensor CKT slow response (bank2 sensor2)
So I am going to replace both o2 sensors tomorrow and hopefully this takes care of the issues.
Here my next questions:
Should I then also clean the injection system, throttle body?
I saw a post for this on the D1 is it the same for my d2? Mike what would you recommend I use for this?
Thanks again for all the help with.
Old Sep 13, 2009 | 06:33 PM
If you are talking about a gas additive, B&G's 44K is by far the best, other wise Seafoam.
If you are talking about cleaning the induction system Seafoam and carb spray.
Old Sep 14, 2009 | 08:00 AM
rj95lss's Avatar
OK so just take the intake off and spray the 44k past the butterfly valve (use whole can) and put the seafoam in the gas tank? And do these both right after I have installed the new o2 sensors?
I just want to make sure this is what is meant.
Thanks again for all your help I am leaving now to go get the o2 sensors.
Old Sep 14, 2009 | 11:40 AM
rj95lss's Avatar
sensors will not be here until tomorrow so I got the carb cleaner and the seafoam. and I bought another full set of 4418 +4 plugs.
Do you think I should wait til tomorrow do do it all at the same time or should I do the seafoam and carb cleaner now?
Thanks-
Old Sep 14, 2009 | 04:17 PM
Thanks-
I would do the throttle body cleaning and induction cleaning now, then new plugs and O2's when they all come in.
Old Sep 14, 2009 | 05:14 PM
rj95lss's Avatar
I am on it now...
Thanks a bunch Spike-
Old Sep 15, 2009 | 01:24 PM
rj95lss's Avatar
Thumbs up Update
Alright...
So last night I did the induction cleaning and the t-body just like Mike outlines in his post. Smoked the whole street out, everyone on my block got a kick out of it and when I got back home after 20 miles of driving it out, there was a "party" going on in my driveway. They all wanted to talk to me and figure out what I was doing to that $50k+ Range Rover, even though I have already told them its a $8k Discovery - I always get that or the "Toyota makes that right?".
Then this morning I put the new o2 sensors on and a full set of 4418 +4 plugs (again).
She runs beautifully, like the day she was new. Its amazing how much better it idles and feels like it has way more power.
Its idle is right at 600, is this right or should it be a little higher?
Thanks again and again you guys have really helped me out and probably saved me a couple of thousand dollars since i started on this forum.
Old Sep 15, 2009 | 03:58 PM
Your idle speed is fine, and remember that the tach on the dash is not accurate, its close, but I would not bet your life on it.
Old Sep 24, 2009 | 12:05 PM
rj95lss's Avatar
Question Its back & more codes...
So everything was running great for about 2 weeks now and yesterday it comes back. Do you think I bought bad o2 sensors?
The idle is low again and at low rpm's it rides ruff.
Here are the codes that came up yesterday:
P0150 - o2 sensor circuit malfunction (bank2 sensor1)
P0174 - system too lean (bank2)
P1174 - manufacturer control fuel/air metering
P0159 - o2 sensor CKT slow response (bank2 sensor2)
I still have the receipts from the o2 sensors. Do you think I should try to go to the auto parts store and make them replace them?
Thanks for the help guys-
Old Sep 24, 2009 | 01:05 PM
humroot's Avatar
Did you replace all 4 O2 sensors?
