Fuel Tank Flush Write up?
Hello all,
New here and was wondering if there is a good write up on dropping the fuel tank to clean it out. Was going to get my moms 2000 DII started but it hasn't been started in about 8 years.
Also, any special tools to replace the fuel filter?
Any suggestions would be greatly appreciated.
Thanks,
Leo
Thanks,
Leo
Hello all,
Thanks,
Leo
Thanks,
Leo
so I syphoned as much diesel out as possible and dropped the tank but it was mega heavy even with it a quarter full. The TD5 fuel filter is located on the frame behind the rear passenger side wheel but no doubt different on the V8 but the diesel filter is a screw on canister type like an oil filter.
Great info guys. Is there an access area from the top for the fuel level indicator (or internal pump)? Like a panel. If so, any special tool or bolt size. Going to bring some basic tools over to my moms and want to make sure I have what I need.
Thanks again!
Thanks again!
nope, these picture from google may help: https://www.google.com/search?q=disc...ed=0CAgQ_AUoAw
Thanks for this.
Found out the hard part is actually getting to the access panel. Had to remove both panels on the sides. Found my issue. 2 prehistoric mice.
Actual problem was the hoses on the internal pump were brittle and broke off. You can also see the housing coming off the electrical wires too.
Sourcing a replacement pump now.
Question: Is this a "non" secondary air injection model? How do you tell?
