Fuel for thought
Old Jan 24, 2020 | 11:15 AM
Dave03S's Avatar
I know Costco says their gas is Top Tier, and so does AM/PM, tried them, not as good as Chevron, Shell, or 76. As mentioned above, if you must save $5 on a fillup by buying cheap gas, you shouldn't be driving a Rover.
Old Jan 24, 2020 | 12:10 PM
Best4x4's Avatar
Here in TX (my area) it’s a 15.00 difference per tank. It goes 2.09, 2.69, and 3.29 on average. So bigger than 5.00 difference. Then if I go up near Austin it’s 2.19, 2.35, and 2.45. Just depends on the area.
Old Jan 24, 2020 | 02:28 PM
11chuck's Avatar
Originally Posted by Dave03S
The topic has been well discussed here but I'll say it again. They ECU (engine control computer) has knock sensors, lower than 91 octane gas can be used but the knock sensors will detect it and retard the timing to compensate. It is a feature that allows you to get going if you run out of gas in the middle of Zimbabwe and have to buy gas from a roadside stand in a plastic 2 liter coke bottle. Driving with the timing retarded will cost you in performance and mpg. It is not worth the few bucks you may save on a fill up. On the same topic, buying top tier gas (not Costco, not AM/PM, not 7-11, etc) will help keep your engine cleaner inside thus keeping you from spending money on fuel injectors, etc. You will notice the difference, and if you don't then something isn't right. Go ahead and shame your sister for marrying the man.
Knock sensors do not detect different fuels. All they detect is knock caused by detonation. Detonation only happens when fuel is ignited at the wrong time. The ONLY difference between 87, 89, 91, 93 and other octance fuels is their resistance to detonation. The variation in cleaning additives used varies between companies/stations, not necessarily the octane rating.
The 4.0/4.6 engines are relatively low compression and are not timed aggressively enough to require higher octane fuel, and from what I have read the air fuel mixture is pretty rich anyway. This means you can use low grade fuel, like you stated, even in middle of africa.
I fail to see why people think the lack of an EGR system means it requires higher octane fuel.
On the other hand, I ONLY use 91 or higher in my 2006 GTO because it is a high compression, aggressively tuned engine. I CAN use lower octane in a pinch, but would not give it over a certain amount of throttle as to avoid detonation.
I'd personally like to hear a Land Rover engineer comment on the decision to put a premium fuel only warning on the vehicle. But keep in mind, it says use premium fuel only, doesn't state anything about an octane rating. Basically just states don't use crappy gas. Does anybody actually data log or have the ability to do so to even check if the knock sensors are activating and pulling timing? I really doubt it.
You can use whatever gas you want. But you're throwing money away using expensive gas on an engine that doesn't need it.
Old Jan 24, 2020 | 03:13 PM
mollusc's Avatar
Just after I got it, I forgot about using premium fuel in my '99 because it was my first Rover and I started filling it with regular instead. Started having misfires, rough idle, and poor performance at low speeds. Highway speeds didn't seem to be a problem but I didn't keep any hard records of mpg and I didn't know the truck well enough to be able to get a perception of how well it was performing under different conditions. This went on for a couple of months, during which time I used fuel from several different vendors including Citgo, Exxon, and Shell.
When I realised that I was supposed to be using premium and filled up with that instead, the problems all went away.
Old Jan 24, 2020 | 05:24 PM
Best4x4's Avatar
Carbon build up = #1 enemy
Old Jan 24, 2020 | 05:48 PM
cvhyatt's Avatar
I use regular unleaded but add Lucas octane booster. I don’t se much difference with mpg, but the engine hums and seems to be much more responsive. It’s really fun when you combine this with sport mode and the Kent cam!
https://lucasoil.com/products/fuel-t...octane-booster
Old Jan 24, 2020 | 07:11 PM
Extinct's Avatar
I've only had 12 Discos, had the heads off of 7, never run premium. typically get 16-17 mpg on the highway. All aluminum engines are not prone to pre-ignition like cast iron because of the heat transmission nature of aluminum. The high octane may have a benefit at high load low rpm conditions, but the transmission tuning and gearing on the Disco means it is almost possible to encounter those conditions. Pre-ignition rarely occurs at high rpm because of the limited time for the flame front to advance. Pre-ignition also rarely occurs on low load high rpm - where the Disco cruises on the highway. Therefore the high octane does not change engine performance in the Disco operating ranges.
Old Jan 24, 2020 | 07:58 PM
redwhitekat's Avatar
Currently in my area it’s $1.10 a litre for 87 and $1.40 a litre for 91 at shell
at 94 litres that’s around $30 extra no thanks
I would really like to hear any explanation from the engineers for the reason they wanted higher octane
Old Jan 24, 2020 | 08:01 PM
how did the engine look when you took the heads off and you ran 87 ??
Old Jan 25, 2020 | 08:08 AM
shanechevelle's Avatar
Every engine I've dissassembled, there is an extreme difference between the build up and appearance.
I agree with Best...of course.
dev99disco
Jan 19, 2026 05:23 PM
NENYMA
LR2
Nov 26, 2012 01:48 PM
bmerritt547
Oct 9, 2012 11:20 PM
gipson
Aug 21, 2009 09:49 PM
