Fuel trims
Old Nov 25, 2016 | 11:58 AM
ShaggySE7's Avatar
Default Fuel trims
Hello
I am wondering what the long term fuel trims should be for a Disco 2? Mine is a 99. My readings for Long Term are.
Bank 1 6.3%
Bank 2 7.0%
Short terms seem to jump +/- 5.0% ish
Old Nov 25, 2016 | 01:45 PM
chubbs878's Avatar
Mine are +\- 2%
Last year it would get up to 8% or more when the purge valve was on the fritz
Old Nov 25, 2016 | 01:54 PM
ShaggySE7's Avatar
Originally Posted by chubbs878
Mine are +\- 2%
I didn't know the purge valve would cause that. Was there any pinging when you had that problem?
Are these numbers you posted for long term?
Old Nov 27, 2016 | 12:20 PM
ShaggySE7's Avatar
Update.
I reset adaptive learning by disconnecting the battery overnight. I expected my long term fuel trims to start off at 0.0%. Well they reset to +7.0%. I drove a little over 200 miles and now they have settled in at 8.6% for both banks. My short terms pretty much switch back and forth between +/- 3.0% Do these numbers sound good to those in the know?
Old Nov 27, 2016 | 02:03 PM
chubbs878's Avatar
Originally Posted by ShaggySE7
Update.
That's what mine is doing: switching anywhere between -3.1% to +3.1%ish
(Both LT & ST similar) and these numbers are strictly highway miles @ 60mph
Old Nov 27, 2016 | 05:42 PM
coors's Avatar
My LTFT's are in the range of +/- 3%
A few weeks prior, my trims were wacky. Swapped out the purge valve which brought trims back within the norm for a motor with 120k miles (+/- 3%).
Jeff Blake
Jul 5, 2016 02:31 AM
TRIARII
Off Topic
Jul 6, 2012 02:23 PM
JumPeR04
Apr 7, 2011 09:52 PM
CandiMan
Appearance & Camping Set Ups
Jun 21, 2008 01:45 AM
APSIS USA
Apr 30, 2008 10:52 AM
