Full squirrel cage alert!
Mike, it looked like just leaves and maybe some black soft foam insulation that was pulled in from somewhere. The blower motor is definitely thankful.
Now I get to pull off the passenger side door panel as my window started to go up crooked. I hear it's a nylon wheel bearing that is possibly broke. Is this a pretty easy fix?
Also my squirrel cage wasn't so lucky... Motor is good though, managed to destroy the squirrel cage it was so good lol. PM if anyone needs motor only.
That black stuff I believe is your air filter in the windshield cowl, brittle/worn and was sucked in. Make sure you replace the air draw filter in the cowl otherwise this will just fill up again. Cut a filter to fit it or buy the kit.
Filter Pollen (Genuine Part # JZL100120) - Land Rover pcv & pollen/cabin filters from Atlantic British
You must be referring to this..makes more sense if it goes somewhere underneath the windshield cowl..
