Full tune up - going for it
Old Jan 18, 2017 | 12:03 PM
Luckyjayb's Avatar
If you pinch the back of those flat head screws with a pair of needle nose pliers, they unscrew real easily. Just remember when u put them back in, to use a larger head flathead screw driver and flare them back out.
Old Jan 18, 2017 | 12:05 PM
Luckyjayb's Avatar
Oh and since you are that far in, I would get the injectors cleaned if you can afford it. Worth every penny. I had one of mine that had 3 out of the 4 holes clogged on one injector.
Old Jan 18, 2017 | 12:48 PM
LR03NJ's Avatar
WOW! Good, i told the shop no to do a Full tume up! LOL!
Good luck brah! Well be here until your full tune up ends. post picts
Old Jan 18, 2017 | 09:16 PM
chubbs878's Avatar
You need to replace the oil seperator in the passenger side valve cover while it is off. Also, disconnect the injectors and remove them. There should be some YouTube videos for testing the spray pattern. Really, you are removing the injectors and replacing the 2 O-rings on each unit. From all appearances, your injector Orings are definitely shot and that causes a lot of problems with engine health and performance.
Old Jan 19, 2017 | 06:27 PM
RawFaith's Avatar
Originally Posted by Friday Night Disco
Couple of questions when I read your post
1. Why not do the O2 sensors?
Had a very tight budget and didn't get codes indicating the 02 sensors.
2. Why not buy a new MAF instead of cleaning it?
Same reason , budget and no codes
3. What about a air filter?
Due with next oil change.
Old Jan 19, 2017 | 06:29 PM
RawFaith's Avatar
Originally Posted by Luckyjayb
That is bad but the rockers look better than some others. I took all mine to the head shop and had them clean em in that ultrasonic bath they use and it got all of the carbon build up out of it. If you can do that, cover the ends with ziplock bags and duck tape and pour mineral solvent in them (I'm talking about the intakes removed from the truck) and that will get that carbon build up out of em. You can disassemble your throttle body real easily if need be or you can take just the butterfly out and clean it real well and then inside of it. Makes it a ton easier
wow!
that thing is spotless!
Old Jan 19, 2017 | 06:30 PM
RawFaith's Avatar
will keep pictures coming.
came to the realization that posting from my phone while working with greasy hands it wasn't a good idea....
Old Jan 19, 2017 | 06:33 PM
Luckyjayb's Avatar
Originally Posted by RawFaith
wow!
yea i I had everything cleaned and powdercoated and since I disassembled it, I went crazy cleaning the throttle body interior to.
Old Jan 19, 2017 | 06:34 PM
RawFaith's Avatar
I was thinking about the removing the injectors and having them serviced.
What is your opinion on the BD injector cleaners? ( I'm referring to the one that it's used when removing the fuel lines and running them in a mix with gas)
Lucky, didn't you have someone in the northeast doing them for you not long time ago?
Old Jan 19, 2017 | 06:36 PM
Luckyjayb's Avatar
wow!
i had a head gasket job to do and went wild, almost cost me a wife but hey it worked out. Here was the final. I'm still waiting on the alternator to come in. Damn shipping.
After
Before
