Fun and adventure!!!!
Old Nov 7, 2009 | 08:42 AM
Baylink's Avatar
Based on the original post, I wonder whether he didn't already have an oil leak, and he's blown a path in his headgasket from coolant to oil, such that they're mixing on the way to the leak.
That would explain the color of the leaked oil, and also the coolant odor.
I think I'd get a pressure test on my cylinders...
Old Nov 7, 2009 | 10:35 AM
ChanchoVerde's Avatar
Will do.
Old Nov 7, 2009 | 10:38 AM
Originally Posted by skatelove303
Motor oil should not have any resemblance to Gravy! LOL it could be your Rear main, Try putting some dye maybe? I dont know if thats 100% safe but ive seen people do it.
Just replaced the rear main when the new tranny was installed last month.
Old Nov 7, 2009 | 09:35 PM
bikingteacher's Avatar
Check the heads--a general pressure test will tell. I was pissing out all sorts of oil from mine and thought i would need to do the oil pan--it was just that bad on the heads. So start there, it is common enough.
Old Nov 8, 2009 | 04:34 PM
Sounds good BT. Thanks.
Old Nov 8, 2009 | 05:10 PM
Ok, I found coolant pooled up in the grooves on the valve cover. Not sure what that means though. That sure does explain the coolant smell.
Old Nov 8, 2009 | 10:59 PM
ljdiscovery's Avatar
It has got to be the small line that runs to the throttle body heater. I don't think that there is any other line with coolant that runs over or on top of the valve covers . Unless, one of the radiator hoses or the radiator itself is shooting coolant back towards the engine. Best to have the coolant system pressure tested and try to track down the source of the coolant. best of luck. Phil
Old Nov 9, 2009 | 04:37 AM
lipadj46's Avatar
Tighten up or replace the throttle body heater plate ($20).
Old Nov 9, 2009 | 08:58 AM
Thanks lip.
slowfiveo
ROAMING WITH FRIENDS
Sep 22, 2015 08:06 PM
Land Rover Dennis
Nov 24, 2014 08:05 PM
humanatek
Mar 29, 2007 11:19 PM
Rallyon
Oct 23, 2006 10:42 PM
