Fuse Box - buy new or used?
Old Feb 22, 2012 | 07:33 AM
ckayak2's Avatar
8th Gear
Default Fuse Box - buy new or used?
My 99 Discovery series 2 needs a new under the dash fuse box, when replacing it, would I probably need to get a new one or would a used one be a good bet?
Also, where are some good places be to buy one?
Old Feb 22, 2012 | 08:39 AM
drowssap's Avatar
try paulgrant@mac.com
Old Feb 23, 2012 | 09:46 PM
buick215's Avatar
What is wrong with the one that you have now?
Old Feb 24, 2012 | 05:59 AM
ATLDisco's Avatar
For some reason, they get moisture in them and it corrodes the circuit boards.
That "fuse box" you are referring to is actually called the Intelligent Driver Module.
When the green board inside that thing corrodes, it causes all sorts of random electrical problems.
I got mine used from Will Tillery @ roverguy.com for $100 shipped to my door.
Never had a single problem with it, and install took about an hour.
Just my $0.02
Old Feb 24, 2012 | 07:46 AM
ckayak2's Avatar
8th Gear
Well, we were having several weird electrical problems, for example the blower motor wasn't getting power (the a/c and heat were working) yet the battery and it were fine. So I finally took it to a mechanic after doing everything I knew, and the internal fuse box under the dash is bad. They didn't tell me if it was moisture or not, but that's what I suspect. I went ahead and bought one new because I wasn't sure about a used one. 320 with shipping.
Blakesrover
Feb 21, 2013 01:43 AM
Rover_Hokie
Sep 27, 2012 07:33 AM
PIROLOGISTS
Jan 27, 2012 08:13 PM
Disco Haylee
Jul 7, 2010 08:54 PM
ferrelltodd
Jul 24, 2005 01:22 AM
