Fuse F2 Blown P0141 P0158 P0161 - SOLVED! (WITH PICS)
Old Jan 22, 2020 | 05:10 AM
JUKE179r's Avatar
Default Fuse F2 Blown P0141 P0158 P0161 - SOLVED! (WITH PICS)
Long story short...
Myrtle ran sluggish. Smelled unburned fuel. 15A fuse F2 popped in engine bay with Check Engine Light (CEL) .
Grabbed Nanocom. Read 3 ECU fault codes:
P0141 - O2 Sensor Heater Circuit Malfunction b1s2 (left rear O2)
P0158 - O2 Sensor Circuit High Voltage b2s2 (right rear O2)
P0161 - O2 Sensor Circuit Malfunction b2s2 (right rear O2) - triggered CEL
Crawled underneath. Found b2s2/right rear/downstream O2 sensor wiring was rubbing against the front drive shaft.
Ordered a set of original NTK #25624 O2 sensors from Amazon at $25 a piece.
R&R'd both downstream O2 sensors with a large adjustable wrench. Repositioned O2 wiring away from moving and sharp edged parts. Replaced engine bay 15A fuse F2. Cleared fault codes. Reset adaptions. Went for a test drive.
Problem sorted.
Hope this helps others...
Old Jan 22, 2020 | 05:44 AM
Sales@lk8parts.com's Avatar
Good find!
Taking the time to trace and inspect paid off. Most people would have thrown o2 sensors at it and called it good.
Old Jan 22, 2020 | 12:21 PM
XRAD's Avatar
Nice! Lucky short did not send 12v to ECU on sensor wire......
LandyMatt
Nov 29, 2015 07:50 PM
CANAMDiscovery
Aug 12, 2013 12:39 PM
wyattparke
Jan 5, 2013 03:05 PM
lipadj46
May 21, 2009 07:57 PM
