Fuses and Gaskets
Fuses and Gaskets
Hi all, Im new here, but read through a bunch of posts and have learned alot.
FYI - I have a 2002 Disco II SE...its recently had a slew of problems...ill pick 3 for the sake of brevity and hope someone has advice.
1) I purchased it without a manual or anything. I am looking for fuse info. I have downloaded the workshop manual and an engine overhaul manual and didnt really see anything as to a layout and what the fuses do. In the fuse box in the engine, there are a bunch of missing fuses...i have no idea what they are for or how many amps...also, there seems to be a hadfull inside missing too...is there anywhere i can download this info for free???
2) I have been leaking coolant for a while and now recently oil. I have often refilled the coolant. It appeared that oil dripped on the manifold and it started smoking. The engine temp went all the way up. Pretty sure the heat stopped getting hot too. I refilled oil and coolant, its been ok for a day or so, but im thinking i have a cracked gasket. Probably need to replace the head gasket...any thoughts???
3) My driver door seems to not seal and/or shut all the way...it looks shut but air gets through the upper part and its loud as heck...if i go through the car wash a ton of water leaks in. What do you guys thing...new hinge pins? theres not dents and or dammage, it shuts and latches fine...
Any help with either and/or both would be greatly appreciated
DiscoMike
DiscoMike,
The page wont let me private message you. If you want to send me your email or something, ill send you my number...
my email is:
thehannimal@gmail.com
my email is:
ty1
10-29-2013 03:18 PM
RoverLady
04-26-2012 08:56 PM
