FYI Adaptive Settings
Old Mar 7, 2019 | 01:04 PM
CollieRover's Avatar
Default FYI Adaptive Settings
"Connector 1 (C0634): This connector contains 9 pins and is used primarily for ECM power input and earth. The ECM requires a permanent battery supply, if this permanent feed is lost i.e. the battery discharges or is disconnected the ECM will lose its adapted values and its Diagnostic Trouble Codes (DTC). These adapted values are a vital part of the engine management's rolling adaptive strategy. Without an adaptive strategy, driveability, performance, emission control, and fuel consumption are adversely affected. The ECM can be damaged by high voltage inputs, so care must be taken when removing and replacing the ECM."
Apparently, being dtached form Battery long enough should cause the adaptive settings to be reset to default.
jackh
Sep 13, 2020 04:39 PM
houm_wa
Aug 5, 2015 11:17 PM
Childeric
Apr 9, 2014 11:43 AM
Savannah Buzz
Feb 16, 2014 08:46 AM
demonfork
Sep 9, 2013 03:06 PM
