Gas Gauge Woes
Old Oct 10, 2022 | 07:52 PM
notch's Avatar
7th Gear
Default Gas Gauge Woes
I have some gas gauge woes and its not that I get 15MPG.
It works some times, others it doesn't, sometimes it shows full tank. Most of the time it is on empty. Its done this for thousands of miles now, even with a new ECU, sending fuel pump, and cluster.
Would anyone be able to tell me where the wire goes from the sending unit to the ECU? I think at this point its the only possibility left. Everything else is new.
thanks
Old Oct 11, 2022 | 05:25 PM
XRAD's Avatar
Do you have the RAVE electrical manual? It's very helpful for these type of situations...
https://discoii.wordpress.com/resources/
Old Oct 26, 2022 | 09:49 PM
notch's Avatar
7th Gear
RAVE was a huge help, thank you.
Traced the two wires from the sender to the cluster, and one was a bit shaky. I ran two new wires from the cluster, up through the ceiling, and down to the carpet in the back. No more issues!!!!
And that was the last of the issues. I've named the truck "Brick" as it is brick red and shaped like a brick. 170k miles down and maybe 2000 more this winter and I'll sell it. Hopefully no more issues.
MisterCee
Nov 30, 2020 10:23 AM
dmenchaca1966
Nov 5, 2020 11:54 PM
TheWildCard
Jul 26, 2017 08:12 PM
98roverguy
May 29, 2007 10:15 AM
drpenaranda
Oct 3, 2005 10:08 PM
