Gas Smell Inside Car
Old Jun 4, 2014 | 06:01 PM
pgk's Avatar
pgk
Default Gas Smell Inside Car
I recently have begun to smell gas inside the car. When I go out in the morning and open the door I can smell it. Any ideas? I see no leaks anywhere. Thanks.
Phil
Old Jun 4, 2014 | 07:29 PM
jfall's Avatar
So you go to the gas station.
You fill it up.
Then you try to fill it again by clicking the nozzle
you do this three or four times.
maybe you bounce on the bumper too -
to burp out the bubbles?
Well, that extra gas goes into the charcoal filters.
And into the cabin of the discovery.
and gas can cause cancer too from excess exposure.
Moral of the story --
When it clicks off - tank is full.
That's it.
Plus fighting the over flow valve on the gas pump also irritates others on the same supply by changing the delivery pressure and making their nozzle click off from the "hammer" effect of your bumping the gas delivery.
So, don't do that.
Old Jun 4, 2014 | 09:17 PM
XCELLER8's Avatar
Phil
had the same issue once a while back.......turned out to be a rotten (rusted) fuel line connector on the top of the pump....it was seeping fuel but never left a puddle.....until I touched it LOL ......, roll up he carpet in the back and have a look
Old Jun 5, 2014 | 03:03 AM
Dane!'s Avatar
I say a cracked fuel pump.
Get under the rear end of the truck and smell for gas...
It could be a bad seal also, but these fuel pumps crack. Well.. Mine did st least....
Old Jun 5, 2014 | 08:47 AM
drowssap's Avatar
gas leaks can be difficult to find because gas evaporates within minutes, you may never SEE the leak
Old Jun 5, 2014 | 08:57 AM
jamestfl's Avatar
1) meh, prolly just a fuse... (thanks Dusty, that's such a classic!)
2) don't use a lighter to look for the leak.
3) sorry- no useful contribution to make.
Old Jun 5, 2014 | 11:33 AM
dusty1's Avatar
might help if it is a crack Interdynamics 374CS - Flourescent Leak Detector Dye | O'Reilly Auto Parts
i have used that junk in everything except the fuel.
Old Jun 5, 2014 | 11:43 AM
RoverMasterTech's Avatar
Could be: O rings on fuel injectors. Evaps problem (P0440?) Fuel pump top cracked, fuel pump outlet leaking, fuel rail inlet leaking. You could jump the fuel pump relay for a while and see where the fuel is leaking.
jmillerau
Sep 7, 2011 07:54 PM
olivia
Nov 20, 2007 07:41 PM
mr.47
Nov 15, 2006 10:22 AM
GasScam
Oct 9, 2006 05:35 PM
jwellis1005
Jul 9, 2006 10:44 AM
