at the gas station and can't shift out of park
Old Jan 16, 2010 | 11:43 AM
herblatham's Avatar
Default at the gas station and can't shift out of park
im at the gas station and I can't shift out of park. when I grab the shifter I can hear a clicking coming from the glove box. ice heard of this happening before on the forum and remember reading something about taking off the cap to the shift ****, but don't know what to do next.
ill just sit here and wait for your guys help lol
oh ya im using my cell as internet so if you wanna call, it be ten times easier for me, I know, I ask for too much lol
8032619164
98 land rover
139000
Old Jan 16, 2010 | 11:59 AM
meltdowndave's Avatar
Not guranteeing anything, but trying to get you out of a fix.
Try this link.
http://www.landroversonly.com/forums...ts-work-37892/
Old Jan 16, 2010 | 12:26 PM
herblatham's Avatar
I couldn't find a fuse of that description, probably because mines a disco I ? my windows work, so do the front and rear windshield wipers. and my brake lights are working as well. this would happen after putting a full tank of gas in.
Old Jan 16, 2010 | 12:30 PM
herblatham's Avatar
alright, so I asked someone to tell me if my brake lights work when I press the brake pedal. they're not, so what do I need to do?
Old Jan 16, 2010 | 01:14 PM
lipadj46's Avatar
You need a new brake pedal switch
Old Jan 16, 2010 | 01:26 PM
Mrmerlin's Avatar
pull off the harness at the switch see if you can jumper the wires, then try to start it/ engage drive
Old Jan 16, 2010 | 01:39 PM
herblatham's Avatar
where is the switch located at? and how would I "jump" it? cause im ion the way to order the part and really don't want to have to tow it
Old Jan 16, 2010 | 01:48 PM
XCELLER8's Avatar
the switch is attached near the brake pedal lever about 10" from where your foot would be...yuo'll see it....it's the only one there, the one with the vaccum hose attached to it is for the cruise.
Old Jan 16, 2010 | 02:05 PM
XCELLER8's Avatar
ok I just pulled my spare switch out of the glove box and checked it with my ohm meter.....there are four terminals, holding the switch with the pins facing you and the half round connection to the left......the 2 pins on the left are connected untill you push the button.......the two pins on the right are connected untill you push the button....I'm assuming the you need a jumper wire to connect the two pins on the right together and the two pins on the left together.....one is probably the brake lights and the other is likely the solenoid for the shift lever
Old Jan 16, 2010 | 02:39 PM
03discoman's Avatar
just remove the shifter ****... take off the shifter bezel and unplug the shift lock silenoid?.. that way you can shift the lever into gear
