Gear 4 Incorrect Ratio
Old Mar 17, 2005 | 12:37 PM
jim_darci's Avatar
Default Gear 4 Incorrect Ratio
I just bought a 2001 Discovery SD. The vehicle has an automatic transmission. About 2 weeks after I bought the vehicle, I had to have a new battery installed. Soon after the battery was installed, my check engine light came on. I hooked up my OBDII reader to it and received the code related to Gear 4 Incorrect Ratio. Does anyone know what this means and what impending doom am I looking at if any.
Jim
Old Mar 17, 2005 | 03:56 PM
Lighting90's Avatar
Default RE: Gear 4 Incorrect Ratio
I understand that sometimes when you fit a new battery you have to reset a few things.. but as I don't have any f this fancy electronic stuff on my landies I don't know how you would do it..
Old Feb 17, 2007 | 11:16 PM
bookerbr's Avatar
I believe I had the same code. I took it to the dealer and I ended up replacing the mass air flow meter on my own. It is a bosch product and easily snaps in place. As soon as it was installed and I drove my disco, service engine light extinquished. Hope this helps.
Old Feb 18, 2007 | 12:11 AM
A low battery will cause the trannys ECU to thru that code. Go to a good tranny shop ask them to read and clear the code and you should be fine.
Mike
jkid
Jun 4, 2008 06:43 AM
riderwoodrover
Nov 23, 2007 07:21 PM
humroot
Nov 13, 2007 08:47 AM
humroot
Nov 11, 2007 08:26 AM
noemad
Apr 16, 2007 10:45 AM
