Gear 4 Ratio Incorrect
RE: Gear 4 Ratio Incorrect
Those codes look like MAF codes along with some misfire codes (P03__). It looks like you need new spark plug wires(get some good ones like Magnacor),spark plugsand probably a newMAF. As it turns out, my MAF was okay. I had a vacuum leak at my intake plenum, so you might want to check forvacuum leaks.There is a plasticfitting connected to a hose on the passenger side that had worked it's way loose.I put some thread tape on it, tightened it up and I've had no codes for over a week now. For you, I think the P0101 is specific to the MAF. I never got that one.
on
1 Post
I got the gear 4 incorrect ratio not too long ago ( last march), and since I had to replace the maf, I decided that I had nothing to loose in trying to fix it. I removed it, and used unchlorinated brake cleaner that I would spray onto a Qtip and gently clean the sensors. Thengenerously sprayed the whole unit andimmediately blow drid itwith my air compressor. By the way, by the color of the Qtips...the sensors were pretty dirty.Worked like a charm and haven't had any problems or codes showing up on my obd2 reader ever since and its going on 3 months.
