Gear shift Handle sticky
Old Dec 28, 2010 | 10:56 AM
mummra's Avatar
Default Gear shift Handle sticky
Got in the Rover yesterday morning and it was excessivley hard to slide the Shift Handke back and forth into gear.The Tranny is shifting of and it goues into gear fin but pushing/moving the handle now takes mor effort than it should (this was not gradual either)
Any insights would be appreciated
Old Dec 29, 2010 | 09:02 AM
keithatcpt's Avatar
3rd Gear
My DiscoII has the same problem. Is the shifter "creaky" when it goes into gear?
The cable that goes from the shifter to the transmission probably has some gunk/moisture/no lubrication in it. I periodically remove the plastic cover around the shifter (the one that says P/R/N/D...) and put some grease on the cable and work it back and forth. Also, you can get under the truck and put some grease on the cable at the transmission (make sure you set the parking brake, block the tires and you don't have the engine running for safety, as you will need to set the shifter in first gear to expose as much of the cable as possible).
Work the grease into the cable and do this a couple of times, shifting will be much easier.
- Keith
Gator Ritt
Aug 13, 2011 02:20 AM
Lee1140
Dec 1, 2009 10:17 AM
APSIS USA
Apr 30, 2008 10:52 AM
Chrisinhouston
Nov 16, 2007 09:59 AM
felipenaves
Mar 20, 2007 01:37 AM
