Gear Shifter Knob Parts for auto Trans
Gear Shifter **** Parts for auto Trans
Does anyone know if you can buy the small clip on top of the shifter that allows the rod to go up & down when you depress the side button? Its function is that of a regular "C" clip but is rectangular and has just a hole and slot instead of the open C like a C clip. Mine is giving me all kinds of trouble, not staying on shaft,moving enough so shifter doesn't fully engage in Park so I can't take the ignition key out or just falling off altogether. Any help or p/n info would be appreciated. I looked on my Rave cd and I can't seem to find any spefic info or parts list for the shifter assy.
Thanks
1997 Disco I 4.0 Liter automatic (obviously
Thanks
RE: Gear Shifter **** Parts for auto Trans
Duplin,
I also need those plastic parts around the shaft and slider assy lol. I can live without them though so let me see if I can find my clip somewhere first. I program the computer controlled machines in a machine shop so if worse comes to worse I could machine something to solve my problem but it would be easier (and cheaper) to just buy the clip if available. But i'll let you know.
Bob
Bob
ORIGINAL: DuplinDisco
I may be wrong..but you may have to find an entire shifter assembly. I'm actually looking for the plastic piece that surrounds the shifter and slides..maybe we should buy a used assembly together and split the costs
Call them first to make sure....
Bob, call www.roverparts.com or hit up the dealer. I got a new clip after I bent mine. It was $5, but well worth it to not have to search.
ORIGINAL: okdiscoguy
How much do you love me? http://www.roverparts.com/Parts/RTC6683.cfm
Thanks bud!
