Getting P0130, P0171, P1171
Could be several things. Bad or cheap o2 sensor. If you have a valve cover leak you'll kill primary aka upstream o2 sensors. These are usually the culprit.
next is an air leak. Upper/lower intake gaskets, leaky valve covers,, vacuum hoses etc.
A falling maf could cause it.
Clogged cat, exhaust leak.
Back injector seals or bad injector (s)
I'm experiencing similar codes in our 99, I'm pretty sure I've narrowed it down the the maf.
EHGIII
03-17-2015 10:33 AM
