Give a little gas to start disco up.
Old Feb 7, 2008 | 07:48 AM
zracin's Avatar
Default Give a little gas to start disco up.
My '95 disco will not start up unlessI give it some gas. What is this an indication of? can it be fixed?
Old Feb 7, 2008 | 08:52 AM
Default RE: Give a little gas to start disco up.
Do you have a check engine light, if so what are the codes?
What has been done, tune up wise, in the last year or so, when was the fuel filter last changed?
Old Feb 7, 2008 | 09:48 AM
zracin's Avatar
a hard start was fixed by replacing 2 fuel injectors by the past owner. other services have included replacement of water pump, replacement of expansion tank, replaced timing cover gasket, new dist.cap, new rotors, timing was adjusted recently, spark plug and wires were replaced, new valve cover gaskets, new fuel pump, new serp. belt, new heater and cooling hoses, and new alternator.all was done by the rover group in cali.
Old Feb 7, 2008 | 09:49 AM
jmt's Avatar
jmt
Could be any number of things.
Start with the basics. Flush you engine and change your oil and air filter.
Old Feb 7, 2008 | 11:22 AM
What plugs and wires, by brand and gap?
What brand cap and rotor, this can make a huge diffewrence.
What about the fuel filter, if plugged it will make for hard starting.
Old Feb 17, 2008 | 11:45 AM
zracin's Avatar
i am going to a local rover specialist and having all injectors replaced as well as a new fuel filter. even if thats not the problem, cant hurt anything
Old Feb 17, 2008 | 11:59 AM
Have him check your fuel pressure regulator too.
Old Feb 17, 2008 | 12:11 PM
Are you wanting to get this fixed or just keep throwing money at it??????????????????????????????????????????
I have asked already, is your check engine light on, what codes do you have????????????????????????????????????
Now you can go waist alot of money or you can start paying attention to questions asked.
By the way, injectors won't fix it.
Old Feb 17, 2008 | 12:39 PM
greg409's Avatar
A little voice in my is wondering about the throttle position sensor (TPS) ?
Being lazy, I'd throw an ohmeter on it while working throttle body linkage by hand, and watch my meter. (especially throttle @ closed to just cracked)
But that's just me.
P.S. I would be suprised if you didn't have codes per TPS but I wouldn't count on it either.
zukijames
Apr 9, 2013 09:30 AM
meltdowndave
Sep 11, 2009 02:19 PM
wileyabbas
May 23, 2008 02:50 PM
EL GALLO
Feb 22, 2008 10:33 AM
KidGid
Jan 26, 2007 11:18 PM
