Glass shop broke A pillar trim
Old Apr 27, 2018 | 03:51 PM
tcr6v1's Avatar
Default Glass shop broke A pillar trim
Getting my windshield replaced and the shop called me to look at rust before they fixed it. While there I noticed they broke the tabs on the a pillar trim. I asked them about it and said i assume you are going to replace what you broke and he says "its 20 year old plastic, I'm just going to glue the tabs back on"
I was already annoyed at this point because I was told the truck would be ready for 5 on Friday and they called me saying they just got the windshield out at 330.
should they replace them? To make it worse they took them off and didnt even realize they were plastic rivets holding them on. Claimed they were push pins. Guy shows me what came out and low and behold it's a plastic rivet. Idiots.
Old Apr 27, 2018 | 04:00 PM
Jeff Blake's Avatar
Similar thing happened to me with safelite. I noticed the a pillars were loose after they left (tip: inspect before they leave, breaking those clips is almost inevitable). I called them up and told them to replace it, and they went the extra mile and replaced both a pillars and the lower cowl, as the colors would be way off if only A pillar was replaced. So yeah, be nice, and make sure they replace it. The company should have a warranty policy and it’s not like the guy you talk to is out of pocket personally, so push to make sure they fix it proper.
Old Apr 27, 2018 | 04:08 PM
Dave03S's Avatar
I have had a glass shop break those twice, each time they gave it back to me without mentioning it... As soon as I called them on it they got new A pillars and installed those. Not sure if they billed the insurance or just ate the cost but I assume it got billed. Next time I'll go for a new matching cowl trim piece too!!! The newer style A pillar trim is matte black rather than the OG gloss black plastic. Is the cowl piece matte too?
Old Apr 27, 2018 | 04:53 PM
Jeff Blake's Avatar
Yes it is. The matte looks good.
Old Apr 27, 2018 | 05:17 PM
Best4x4's Avatar
I remove everything before I take it to them or they show up!
Old Apr 28, 2018 | 06:32 AM
zuke's Avatar
I need new glass. What is the best way to get them off?
Old Apr 28, 2018 | 11:50 AM
Richard Gallant's Avatar
Atlantic British has a video on removing and installing
I used this method at a wrecker, I literally boiled water, dropping a towel in it and leaving it on the a Pillar trim for a couple minutes to heat everything up. Poured the left over down from on top so it ran underneath.
Figured if it was warm or hot the plastic would be softer and less likely to break.
It worked but whether I was lucky or the hot water helped I have no idea.
I have not put the new ones on yet as I am trying to figure a way to reinforce the tabs.
I am thinking some pop can aluminum and JB Weld Epoxy. Form a pocket with wings. Epoxy the the pocket and wings to the plastic tab and A pillar underside. Use the metal clip to hold it tight while it drys so it will socket correctly.
That "should" prevent the tabs breaking. Then a bit of grease on the metal bits before assembly to reduced rusting and ease assembly. I can at least test with the old broken ones to see if works.
Old Apr 28, 2018 | 11:58 AM
Jeff Blake's Avatar
Why remove them yourself, and be liable for damage? Have the shop do it, and they will replace them when they get broken
Old Apr 28, 2018 | 01:55 PM
tcr6v1's Avatar
the issue I'm having is getting them to replace what they broke. And the fact they broke the tabs and didnt even tell me, I just happened to see it.
the ""manager"" (who was early 20s) is saying its 20yr old plastic so they aren't liable because I should have know it could happen. Not even offering a discount.
Old Apr 30, 2018 | 10:51 AM
mr. choodles's Avatar
Richard has the right idea. Make sure when you work on the plastic parts, the plastic is warm. You do NOT want to do this job early in the morning when things are cold. Also, you must not twist the panels at any time. Pull them straight out. If you twist, you'll break off the tabs for sure.
When replacing the windshield: Take the A-pillars off. Mark the frame where the lower cowling sits, take the cowling off. Take off the rail drips and give the car to the shop just like that so that they cannot break those expensive plastic parts.
On a final note--if you have the original A pillar trim and the cowling, replace them with new parts. Really lifts up the face of the truck :-)
