Got the dreaded oil light today...
My 03 falls in the bad vin and I cranked it to leave my fiancees and the oil light stayed on for 5 or 6 seconds longer than the other lights. The light turned off before I could turn the car off but it definitely must be failing as my oil is about 10 days old (royal purp 10w40) and I used the upgraded 3001 filter. Checked the levels and they were fine. I was about to garage the discovery for a while anyway to put on the lift, sliders, bumpers, lights, ds, cdl, etc and I had already ordered the new pump so I'm EXTREMELY happy I caught this while it was just started up before the engine started knocking or before it locked up all together.
Engine was still running perfectly smooth with no noise when i turned it off and I won't turn it on again prior to adding the new pump.
My school's off-road club is going out to some local trails this weekend so I guess I'll have to take the FJ instead of the discovery. FJ is a work in progress but runs perfectly and the trails this weekend are supposedly very easy and it is more of a get together. Will probably have the discovery garaged for three weeks or so now and I'm also going to install an oil pressure gauge prior to running her again.
I want to redo the shuttle valve while I'm doing everything else but the kit seems to be $795 and that is outrageous.
I can't believe how lucky I was to have the light start to come on and notice it before any damage. I hooked it up to read the codes and nothing came up??? I guess since the light turned back off before I turned the car off that that might cause them not to show up?
Do not drive it till you are able to set up an appointment with a mechanic to leave it over night then do a cold idle pressure test, the cols at 2000 rpm's, idle when warm and at 2000 rpm's. That's when you will know what is going on.
Get back to us with the pressures.
Not mad at all about this happening as I needed to go ahead and switch out the pump and check out the whole oil system or whatever. My buddy is letting me borrow his flat bed whenever I need it which in the long run will save me a ton of $
