got my amigo codes.. want to make sure i am doing the right fix
so just before i tear into this i want to make sure I understand what i am see and what i think i should be doing.
This is what i got from my ABS scan (ABS AMIGO SCANNER)
1.--Current Faults---->
Active Faults:
064:Front Right sensor electric fail
114:Shuttle Valve Electric Failure
Logged Faults:
<-END Faults
With this in mind should i tackle the front right sensor first and if so what is the process, i think its a new hub right????
With that done i amuse its the "Option B Shuttle Valve rebuild" listed here.
http://www.landroverclubvi.com/abs-mod.html
is my thinking sound, anything im missing or something else i should do?
Thanks in advance for the help.. you guys have been a great help!
Dave
Active Faults:
Logged Faults:
<-END Faults
Dave
and what is "amigos"?
TIA
The sensor is in the hub and when the hub starts to go (these are unit hubs that are prone to failure) the gap between the sensor pickup and the "notches" in the hub get too large and you get a sensor error. The sensors can fail also but in my experience the hubs are ususally the cause.
Search for the 3 amigos on this forum.
on
If you go throw a panic stop from 30 MPH on a loose surface, can you feel your ABS pulsate thru the brake pedal?
You can use a ohm meter to check you sensors. I believe each sensor should ohm out around 2000 ohms. Double check that figure. With a electrical failure fault you should find that the front right sensor ohm's out bad. The shuttle
valve fault is likely the abs module... Bypassing the svs circuit is the likely quick fix.
