Got a tranny problem...any help would be great
Old May 2, 2008 | 03:17 PM
Chillbred's Avatar
Default Got a tranny problem...any help would be great
Driving along in my '99 disco II today and my tac. started reving all the way up and I wasn't going any where. then My "D" and the S and M (ON THE DASH) started all blinking. I have no reverse and no drive in any gear, this is the first problem I have ever had with the tranny, can anyone help or even be able to tell me weather or not it's shot....PLEASE HELP!!
Old May 2, 2008 | 04:33 PM
Default RE: Got a tranny problem...any help would be great
You will have to have it towed and have the codes read. The only thing that I can think of is it is out of fluid.
The only way to check the fluid level is to pull the plug on the side of the tranny and stick your finger in the hole and see if you feel any trans fluid.
I am not 100% on this for your trk, it is a DII but a early model so I would look for a dipstick under the hood first.
It should be on the pass side next to the firewall. If no dip stick then you have to pull the plug.
Old May 2, 2008 | 08:48 PM
The is no dip stick on any D2.
How many miles on your truck, how often does the tranny get serviced??
Old May 2, 2008 | 11:16 PM
Chillbred's Avatar
I've never had the tranny serviced, I've only had the thing just over a year. I have 132,000 miles, but I do have the paper work saying the tranny has been replaced...not sure when but probably about 50,000 miles ago.
Old May 3, 2008 | 10:44 AM
The transmission needs to be serviced every 30,000 miles, that means change the fluid, every 30k.
Have the fluid level checked at EVERY oil change, if you have a small leak you may not see spots on your driveway, but overtime you can run the thing out of fluid and burn it up.
Was it replaced 50k ago? Did they put in a new one or a used one?
Check your paperwork and let us know.
Old May 4, 2008 | 07:55 PM
Chillbred's Avatar
Hey guys I have a buddy of mine (who also happens to be the service manager at my local ford dealership) pull it into his shop and is having his tranny guy take a look at it for me, I'll let you know what I find out...keep me in mind if you hear about any tranny's for sale...and thanks a bunch for all the help so far.
Old May 5, 2008 | 06:55 AM
rus4dr's Avatar
My son had a problem with the vehicle not coming out of park, changed fuses and cured that problem, now engine revs on its own and drives bad in both L and H. Will have him check transmission fluid, any other items that could be electrically related to check?
Old May 5, 2008 | 03:22 PM
Chillbred's Avatar
BAD TRANNY!!! Just got the call, looks like something in the tranny snapped and destroyed the transfer case and tranny, so now I need both anybody got a good place for used ???
Old May 5, 2008 | 06:26 PM
So your double cardon joint on your front driveshaft broke.
Old May 5, 2008 | 07:27 PM
Chillbred's Avatar
I don't know about the doubl cardon thing??? but what I was told was something in the tranny snapped and when they looked at the transfer case it was covered in red fluid. I can find out exactly what happened or what they are telling me, then hopefully someone can tell me what they think...I thought it was kinda hard to destroy a transfer case
Perfectphoto
May 31, 2019 08:27 AM
dobe1canobe
Mar 28, 2014 06:53 AM
Newroverguy
Jan 26, 2011 10:29 AM
FightOnUSC79
Jul 20, 2010 03:15 PM
03discoman
Audio/Visual Electronics
Dec 24, 2009 09:16 AM
