For grabs in CT.
Pembroke Grey LRC476 is a traditional single part Synthetic Coach Enamel paint. It was used from around 1991 until 1994 on the Range Rover Classics. It was also known as Pembroke Grey, which was used on the Defender Range. Land Rover Pembroke Grey LRC476 – Further information for your interest
Here is what the sellers link about the paint
https://www.paintman.co.uk/shop/land...e-grey-lrc476/
- Technical bits you may want to know. Paintman Land Rover Pembroke Grey Coach Paint is a traditional, ultra high quality, high build, long oil synthetic enamel. It is ideal for brushing, rollering or spray application. If you are choosing to spray your Pembroke Grey it will require diluting by around 5-10% using the correct Paintman Coach Enamel Thinners. It is important to use the correct thinners as not doing so could impair the high gloss finish or delay drying times.
- Paintman Land Rover Pembroke Grey gives you the ultimate high gloss, build and scratch filling properties. This also combines with excellent water resistant, flexibility, toughness and good exterior durability. Paintman Coach Enamel is manufactured to give an extra long wet edge time allowing it to be brushed without brush drag.
- Don’t forget when using Paintman Coach Enamel to ensure surfaces being painted are dry, and must be cleaned to remove all contaminants.
- Sizes available. Land Rover Pembroke Grey is supplied in 1 litre cans for your convenience. If you require different quantities please contact us.
- For more information please have a look at our methods of use page . Alternatively, ask us a question at our Contact page.
- Everything we stock we use. There is no compromise. Quality is our key we will not compromise on this goal.
The rock sliders look like they have a fair amount of rust. Makes me wonder what the frame looks like. West Hartford is about 45 minutes north of me and they use tons and toms of salt on the roads up there.
The US military 40mm ammo can is an interesting substitute for the normal side bins.
I used up all my excuses. Last I told her, its cheaper to get the truck instead of getting new tires. She agreed. Next, I'll be sleeping in a 5 door room.
Cheers!
raeuspius
05-28-2014 12:29 PM
Willie00d2
39
05-03-2013 09:17 AM
