Grease fitting locations and size
I did an oil change on the truck and wanted to grease the drive shaft but the grease gun that I have won't fit the grease fittings. It seems as though the fittings on the drive shaft are smaller then the fitting on the gun. What size or type of fitting do I need? I was also wondering if their are any other grease fittings on the truck that could use some greasing periodically.
I thought grease guns were fitted with a standard tip. Go to Harbor Freight and pick yourself up a new gun. Grease the (3) on the front prop and (1) on the rear shaft.
You can probably pick up a new tip like the one below, if your gun has a removable tip.
Not sure if the chassis or suspension have any fittings. Doubt it.
