Greasing Deiveshaft Question
Old Nov 16, 2017 | 02:14 PM
CollieRover's Avatar
Default Greasing Deiveshaft Question
So I just greased my driveshafts, and whenever I do it I get grease all over the place. Sprays onto the Cat, oil pan, up to the starter when the driveshaft spins.
Am I overdoing it or what?
Old Nov 16, 2017 | 02:33 PM
KTriplett's Avatar
I was taught to pump until you hear the ‘crack’ when working with heavy machinery at a young age. I’ve always followed this rule.
Old Nov 16, 2017 | 02:35 PM
OffroadFrance's Avatar
Hi, possibly. You should note whether the grease emanates from all of the UJ's you are greasing and if not wrap an electrical tie wrap tightly around those where the grease is flowing out too freely but don't forget to remove them afterwards. Greasing UJ's has gotta be one of the worst jobs on a D2.
Old Nov 16, 2017 | 04:08 PM
Motorhead1's Avatar
Yes sir!
Old Nov 16, 2017 | 06:08 PM
The Deputy's Avatar
The only time I might give each joint extra (after the crack/snap)...is when...discolored grease from water distortion appears. I'll keep pumping grease until clean/fresh grease replaces discolored cruddy stuff. Wiping away excess to avoid splattering.
Brian.
Old Nov 16, 2017 | 07:51 PM
It is a pain, but you’re making it harder!
Grease is just such a pain in the *** to cleanup. Thanks for the thoughts guys.
Old Nov 16, 2017 | 10:33 PM
mln01's Avatar
Make sure that fresh grease comes from each of the four caps on each U-joint. Yes it can be messy. Deal with it. Just clean it up as best you can when finished.
Old Nov 17, 2017 | 03:16 AM
The Deputy's Avatar
If you live in a cold climate region, keep your grease gun in a warm location or at least bring it in the house for a few hours prior to using. This will help immensely, pumping stone cold, almost rock hard grease through a zert can to mighty difficult. Once the grease is in there, the spinnning motion and heat generated will move grease to the cups of the u-joint.
Being religious about doing it helps too. Every 3 or 4 thousand miles, depending on conditions, will keep fresh grease suspended in the cups and not allow it to become hard and baked onto the needle bearings inside joint.
Brian.
Old Nov 17, 2017 | 07:21 AM
Brian.
I disn’t Think of having it in a warm spot. Good idea.
Old Nov 18, 2017 | 02:17 PM
Problem is CollieRover the grease will take the 'least line of resistance' and so continue to ooze out of the nearest UJ to the zerk in most cases and no matter how much grease you pump into the UJ zerk it will never lube all the legs of the remaining UJ's in many cases and all it does is waste oodles of grease onto the floor.
