greasing the drive shaft
Old Oct 7, 2012 | 09:24 AM
mylesman12's Avatar
Default greasing the drive shaft
I found 4 grease zirks on my 2004 Discovery SE drive shafts. Two on front and two on back.
I greased the u joint and the prop shaft zirks until grease squirted out.
Am I missing any grease zirks, and is this the updated drive shaft set up?
Old Oct 7, 2012 | 09:36 AM
lr2001silver's Avatar
Banned
MY BAD I MISREAD THE SHAFTS PART GUYS now it needs rebuilt now
Old Oct 7, 2012 | 09:46 AM
suzukisam967m's Avatar
if there are only two on each one wouldn't that be a factory shaft? one for the slip joint and one on the one greaseable zerk. shouldn't the updated shaft have four? on the front shaft. I'm just asking...
Old Oct 7, 2012 | 09:51 AM
There are 4 on the front and 2 on the rear. You need to have that front shaft rebuilt or replaced before it fails and takes out your tranny. Each of the 3 front u-joints must have grease fittings.
How mechanical are you, if you think you can rebuild the front shaft, send me your e-mail address and I will send you a PDF file that will walk you thru it along with good part numbers.
cagusmc's Avatar
Yes, updated shaft should have 4 on the front shaft.
Old Oct 7, 2012 | 09:52 AM
Banned
. A good shaft is going to have 5 not 4 places for grease
Old Oct 7, 2012 | 12:46 PM
bwilliam's Avatar
You probably know this, but the slip joint grease point has a threaded plug that is removed with small hex wrench, and fitted with a spare grease zirk.
Old Oct 7, 2012 | 01:03 PM
The 5th one being for the centering ball if the shaft was rebuilt absolutely first class.
Old Oct 7, 2012 | 01:33 PM
Banned
Only way to go in my opinion, if I am going all in on a high failure part I never want it to give me problems. Never can over stress the importance of properly greasing moving parts.
Old Oct 7, 2012 | 09:10 PM
mylesman12's Avatar
The front shaft must last longer than you think. My car has 140,000 miles and these appear be the original shafts. I admit I don't know the car's history except I bought it with a blown head gasket and multiple warning lights ( repaired now )
From the comments here, I'm guessing its the front drive shaft that fails. And per a couple of comments the "updated" shaft has 3 u joints.
I'm going to start looking for an updated front shaft.
Many thanks for the helpful comments.
