greasing front drive shaft
Old Jul 4, 2009 | 03:06 PM
chad420's Avatar
Default greasing front drive shaft
new to the disco game and was wondering if there is a certain type of grease i should be using to grease my driveshaft????
Old Jul 4, 2009 | 04:02 PM
antichrist's Avatar
Any grease is better than no grease.
Ask 20 people and you'll get 20 different brands of grease.
I off-road a lot so I use Castrol Pyroplex Blue. It's made for heavy trucks used especially in harsh environments and is formulated to get tackier when it gets wet, rather than fall apart like some grease does.
Old Jul 4, 2009 | 04:10 PM
chad420's Avatar
i dont do any off roading...just for regular maintenance...I had my front driveshft rebuilt with greseable u joint...there should be three grease fitting correct??? How bout the rear driveshft??
Old Jul 4, 2009 | 04:19 PM
Yes there should be three grease fittings on the double cardon joint.
Just go to AutoZone and buy a grease gun and Valvoline grease.
I use Green Stuff, it is made for farm equipment, same as AntiChrist, heavy duty applications and great for high dust and lots of water.
Grease the u-joints at every oil change.
On a DII the rear driveshaft does not have grease fittings.
Old Jul 4, 2009 | 04:54 PM
When you had the front shaft rebuilt, did they install a new centering ball kit, if not, it will fail shortly.
As for grease, any of the better synthetic greases will work well, grease them twice a year and don't forget to do both slip shafts also.
Old Jul 4, 2009 | 04:58 PM
humroot's Avatar
There are several grease fittings on the DII rear drive shaft. 1 on the u-joint and 1 for the shaft. There is the rotoflex, which does not take grease.
Old Jul 4, 2009 | 05:03 PM
Torancis_LR's Avatar
I use the http://www.greengrease.net/.
Its great if you live in winter months with the salted roads.
Old Jul 4, 2009 | 05:14 PM
chad420's Avatar
now easy on the comments (im a newbie) but when greasing do i hit all three fittings or just one and watch for the grease to come out???? and yes i had the centering ball kit installed when my driveshaft was refurbushed.....
Old Jul 4, 2009 | 06:24 PM
You pump in grease until it comes out, then move to the next grease fitting.
Old Jul 4, 2009 | 06:26 PM
You pump in, in small strokes, a very small amount till you see the cup boots swell up, then stop.
As for the slip shaft, you will need to remove the plug, insert a grease fitting and then bump in a fair amount of grease, reinstalling the plug afterwards.
