Groaning noise in steering?
I have an 03 Disco that makes a groaning noise when I turn upon startup. From what I have found on the web it is probably the shroud on the steering column. Has anyone seen a thread where the fix is shown!! Only way I can do repairs is step by step or pics as I am not a mechanic!! Also what would be the proper lube to use for the shround?
Have you definitely isolated the noise to the shroud? I'm not sure what conditions you're hearing it during, but I'm having possibly a similar issue. I can hear a groan when I cut the wheel all the way to the left, and only when I'm moving. Turning to the right I don't hear anything. Also, when I'm stationary I can lock out to the left and not hear a single thing.
Actually I only hear the noise when I start up and make the initial turn of the wheel. I'm not 100% sure it is the shroud but from the small amount of research I have done it is the most likely cause. I can feel the vibration through the wheel and it sounds and feels like the cause. If you are hearing the noise at the extreme it may be a different issue because my noise only happens when I initiate a turn to either side.
Sort of like a non working wife asking you more money for expenses.
That's just how it is.
Will groan upon rapid turn when cold.
I replaced the power steering pump and the fluid.
To cure it - you will need to replace the steering box.
In the big picture of life "who cares"?
It groans when cold - well, that's life.
