Groaning noise in steering?
Old Sep 13, 2012 | 09:13 PM
robgusto's Avatar
Default Groaning noise in steering?
I have an 03 Disco that makes a groaning noise when I turn upon startup. From what I have found on the web it is probably the shroud on the steering column. Has anyone seen a thread where the fix is shown!! Only way I can do repairs is step by step or pics as I am not a mechanic!! Also what would be the proper lube to use for the shround?
Old Sep 13, 2012 | 09:38 PM
FLDiscoII's Avatar
Have you definitely isolated the noise to the shroud? I'm not sure what conditions you're hearing it during, but I'm having possibly a similar issue. I can hear a groan when I cut the wheel all the way to the left, and only when I'm moving. Turning to the right I don't hear anything. Also, when I'm stationary I can lock out to the left and not hear a single thing.
Old Sep 13, 2012 | 09:45 PM
briancbev's Avatar
FWIW, my 01 has made that sound upon turning at startup for years. Personally, I wouldn't spend any time tracking it down (I haven't had any problems yet), but I am curious if you find out what it is.
Old Sep 13, 2012 | 09:53 PM
robgusto's Avatar
Actually I only hear the noise when I start up and make the initial turn of the wheel. I'm not 100% sure it is the shroud but from the small amount of research I have done it is the most likely cause. I can feel the vibration through the wheel and it sounds and feels like the cause. If you are hearing the noise at the extreme it may be a different issue because my noise only happens when I initiate a turn to either side.
Old Sep 13, 2012 | 10:04 PM
FLDiscoII's Avatar
Ah, gotcha. Definitely not the same issue then. Mine is only when the wheels are moving and cut to left.
Old Sep 14, 2012 | 12:24 AM
jfall's Avatar
Sort of like a non working wife asking you more money for expenses.
That's just how it is.
Will groan upon rapid turn when cold.
I replaced the power steering pump and the fluid.
To cure it - you will need to replace the steering box.
In the big picture of life "who cares"?
It groans when cold - well, that's life.
Old Sep 14, 2012 | 07:39 AM
robgusto's Avatar
I guess I should treat it like the wife and ignore her when she groans!
Old Sep 14, 2012 | 09:43 AM
How many miles on the truck, when did you last flush the steering system?
Might want to start with a steering flush and free up your valving.
By the bay the noise is not because of the fan shroud.
Old Sep 14, 2012 | 10:05 AM
Madlands's Avatar
I had a loud groaning noise when I turned the wheels after starting up a few months back. I drained all the power steering fluid and refilled with Lucas power steering fluid and I haven't had it groan again in the last 10,000 miles.
Old Sep 14, 2012 | 12:10 PM
robgusto's Avatar
Going to pick up some pow steering fluid tomorrow and do a flush (inbetween football games!!!), I will report back in a few days.
