Guess rattle cause on startup and coasting
Old 07-08-2014, 09:07 PM
Two Rock's Avatar
Failing water pumps in my experience have a rough worn bearing "howl" most prenounced at idle, not a metallic rattling noise at all..replacement is straightfoward
Old 07-14-2014, 04:10 PM
nosup4u's Avatar
the water pump replacement was a success. the noise continued!
i spent another half hour poking and listening, it is the engine side plastic radiator shroud. i need to either shave it back a bit or find a way to tighten it back to the radiator. it seems to touch the viscous fan at times. makes sense with the coasting, downhill, non accelerating usual cause of noise, the engine probably shifts a millimeter or two on its worn mounts causing contact.
Old 09-20-2014, 07:55 AM
nosup4u's Avatar
finally figured this out. the item popped out in the pic that holds the hard line was loose in its hole. just enough that it would only rattle under momentum changes for a bit then settle back in.
colin2496
04-22-2013 07:46 PM
tflem1
08-11-2012 07:34 AM
batiscan
05-26-2011 06:18 AM
spartan101
04-11-2010 10:24 PM
Philhowe
03-29-2010 01:49 PM
Quick Reply: Guess rattle cause on startup and coasting
