Guide: Electric Water Pump Install and Thermostat Delete
I didn't go back and read your OP. Did their website or documentation specifically discuss a D2? If not, (or even if so) are you sure you have the hose routing correct? i.e., is the pump in the right place in the system? If they weren't specific instructions for our trucks, are you sure you interpreted their advice correctly? Have you drawn out the coolant flow in your arrangement? How does it compare to the diagram in RAVE? If you have failed to simply replace the stock pump with the EWP, and instead changed to flow routing, that could be your issue. I'd confirm all of that before adding a tstat. If you have a problem, you would still have a problem after adding a tstat. From what you've said you might still need one, but don't keep chasing a theoretical problem while missing the real problem.
As far as flow, there is no longer a radiator bypass. I removed the T joint at the engine exit, so that hot coolant goes straight to the radiator instead of having the potential routing to the thermostat. You can see this in photo 6 above. I removed the thermostat, as well.
So basically coolant goes to the radiator no matter what, which is what the EWP is designed for.
I have a 180* inline t-stat on hand, which I'm going to try installing to see how that changes things.
May have to engineer a solution to that...TBD.
I think you will be fine with the thermostat. If you lived in a hotter climate the system would be a very big improvement in the cooling, suspect you may see a big improvement in temperature performance pulling a grade in the summer.
If I understand your post correctly, are you suggesting returning to the OEM flow setup and moving the EWP location? What do you think about just adding a 195*F inline t-stat? This would be a pretty easy addition to the existing design. I noticed Davies Craig mentions in their documentation that a thermostat may need to be used in cooler climates, with 2 holes drilled into it.
I think at this rate, I'm either willing to add an inline t-stat, or go back to OEM setup entirely since I had consistent 195-205 temps with OEM. The fans have been the bigger value-add anyway.
You could use the standard pump to circulate as normal, and use the EWP to force feed coolant from the radiator, when the engine gets hotter. You can't really have no circulation though the block, as coolant near the exhaust ports and combustion chamber needs to absorb far more heat than the coolant at the bottom of the cylinders (for example). Circulating it helps keep it even and warm up the engine more evenly. The coolant temps inside the heads could skyrocket, while the temp sensor location could remain cooler, with no circulation. Circulation is pretty standard practice, even on vehicles trying to meet ridiculous emmisions standards, that compromise long term reliability, for better emmission ratings.
Its really the full force through the radiator that's required to overcome/prevent a hot engine (as long as the radiator has enough cooling capacity).
You could stick with the OEM flow setup and add the EWP into the radiator line, to suck cooled coolant, from the radiator - that's the biggest issue with the OEM setup - the flow through the radiator is limited, either because the pump don't circulate enough coolant at low RPM's in particular, or the OEM thermostat isn't opening all the way, to block the bypass return port and force full flow from the pump, to be sucked from the radiator. Whether it pumped from or too the radiator shouldn't matter, though the pump is probably more reliable on the cooler side.
There are other options for a thermostat housing with full bypass too, often in aluinium housings too. I know BMW and similar were using them in the 70's without issue, there must be newer, more available options too. That's what I'd go for.
Just the fact they suggest holes in the thermostat, puts me off them - it defeates the purpose of the thermostat, by a percentage... it's the same as having a thermostat that doesn't close correctly, which leads to engines running under temp.
You could stick with the OEM flow setup and add the EWP into the radiator line, to suck cooled coolant, from the radiator - that's the biggest issue with the OEM setup - the flow through the radiator is limited, either because the pump don't circulate enough coolant at low RPM's in particular, or the OEM thermostat isn't opening all the way, to block the bypass return port and force full flow from the pump, to be sucked from the radiator Home Gym Ab Workout. Whether it pumped from or too the radiator shouldn't matter, though the pump is probably more reliable on the cooler side.
You can't really have no circulation though the block...
For a traditional loop system...you're right, I don't quite know why they'd want holes, but again the DC controller becomes a thermostat in that set up anyway.
Happy to report that installing the Inline Thermostat 180F made a big difference! The engine reaches temperature in about 5-10 minutes rather than 30 minutes. The only major downside so far is that I no longer have a bleed port and had to unclamp hoses to bleed.
Usually bleeding not needed with inline thermostat, you can turn pump on full spped before thermostat opens.
