guys, I need some help!!!!
Old May 6, 2008 | 08:38 PM
lennie5936's Avatar
Default guys, I need some help!!!!
all 4 cylinders on passenger side will not fire.
cap,rotor,wires,firing order, spark, its got it all correctly........ all 8 cylinders have 155-158 lbs. of compression. got another fuel injection module and still acts the same.
I'm convinced the 4 cylinders are not getting fuel. What other option do I have, as to what sensor regulates the injectors pulsing?These 4 cylinders aren't getting fuel fuel... [align=right][/align]
1995 discovery 3.9 automatic
Old May 6, 2008 | 08:53 PM
Default RE: guys, I need some help!!!!
Are the plugs getting wet?
Old May 7, 2008 | 12:05 AM
lennie5936's Avatar
no, they don't appear to be wet at all. and no heavy oder of gas on them when pulled. when the engine is running, i can rest my hand onto the exhaust manifold on that side, so i'm not even getting an occasional firing on that side
Old May 7, 2008 | 12:07 AM
lennie5936's Avatar
also, the little box with digital readout, under the passengers seat, showing 68 ???
Old May 7, 2008 | 02:02 AM
HoustonDM's Avatar
Ill ask my father tomorrow when I wake up, if somebody doesnt help you out by then...
-Houston
Old May 7, 2008 | 01:41 PM
NiteTrain's Avatar
ORIGINAL: lennie5936
does this read out show error codes or something?
Old May 7, 2008 | 01:56 PM
cptshanman's Avatar
Yes.
Old May 7, 2008 | 08:52 PM
lennie5936's Avatar
i'm now certain, its all a problem with the harness or main computer as the bad side shows 14 volts on both prongs constantly when running??????? verses 4 volts on one prong and nothing on the other on the good side
1995 discovery, 3.9 with distributer
Old May 7, 2008 | 10:36 PM
HoustonDM's Avatar
What kinf of Battery/ Terminal connections do you have?
-Houston
Old May 8, 2008 | 10:02 PM
bobm's Avatar
ihave a similar problem have you figured it out yet
