guys im stumped!
Old Dec 7, 2010 | 01:57 PM
chiperio's Avatar
well im not so sure it is a lifter now. I have cylinders 1,3,5,7, misfiring and the tapping noise is coming from the passenger side. I am almost thinking it could be a knock sensor- doesnt one cause the odd cylinders to misfire and one cause the even. If it is not in sync with the crank pos sensor? I have a O2 sensor running lean on that side too.
thought it could be a coil to but since one runs a combo of even and odd cyl rulled that out. Its just wierd how its only the odd cylinders misfiring.
Old Dec 7, 2010 | 02:23 PM
NiteTrain's Avatar
I have never heard of any knock sensor causing half your engine cylinders to mis-fire..but I am not familiarized with the workings of the rover knock sensor. I think it's time to start doing some investigating...fuel, spark, compression test, cylinder leak down test.
Old Dec 8, 2010 | 04:24 PM
D2's Avatar
D2
I had similar symptoms at one time. replaced a cracked exhaust manifold and a bad MAF. This took care of the problem. So you might want to check them both.
kid A
Jan 13, 2016 06:10 PM
jctownsley
Jan 3, 2009 10:57 PM
rphotographer
May 11, 2007 07:27 PM
MRDM1
Mar 16, 2007 07:03 PM
Elhoff
Jun 9, 2006 10:48 PM
