H2 Hood Vent modification for D2!!
Old Jun 10, 2010 | 10:56 AM
  #21
DiscoWest's Avatar
Like the idea if you can do it well, good luck. Did you ever pull the weatherstripping off the sides of the engine compartment? I found that works well for reducing underhood temps.
Old Jun 10, 2010 | 04:46 PM
  #22
Now HERE is a cool hood.
Old Jul 9, 2010 | 01:05 PM
  #23
yloDiscoII's Avatar
What's the latest discoman? Did this project get abandoned?
Old Jul 9, 2010 | 01:57 PM
  #24
bosshogt's Avatar
Default Hummer H3 Billet Hood Vent Panel New In Box
This looks like a good install...since it screws on top and sticks up. I would powder coat it matte black. And it is metal...no plastic cheap stuff.
Why not turn it around so it rams air in your engine compartment? Does anyone think it would make a bunch of wind noise? I already have the hood blackout? $200 is a a bit pricey though.
http://cgi.ebay.com/ebaymotors/Humme...item4cf0452b48
03discoman here is one with no sides to fill up with mesh.
http://cgi.ebay.com/ebaymotors/06-07...item255bc66d89
Old Jul 9, 2010 | 02:58 PM
  #25
AK Rover's Avatar
Originally Posted by Spike555
Wow, I was just at www.hummer.com and the H2 comes with a 6.2L V8, who in the hell needs that big of a engine unless you are a contractor and you need to pull a heavy load with your 1-ton pick up every day of the week.
I mean seriously? Soccer mom needs 6.2L's of gas guzzling Republican oil embedded power?
The 454 cid is 6.6L, so that has to be what, around 400 cid?
No wonder GM went bankrupt.
Everything Hummer but the H1 for the military is absolutely ridiculous and a huge waste of space.
I do not like the vent.
The 454 is 7.4L. 6.6L is a 400cid. 6.2L would be somewhere in the 372cid area.
Old Jul 9, 2010 | 05:45 PM
  #26
But the 350 is 5.7 liters, so how can a 6.2 be smaller than 5.7 in cid?
Old Jul 9, 2010 | 05:50 PM
  #27
http://en.wikipedia.org/wiki/Chevrol...l-block_engine
Not that I totally trust anything on Wiki.
http://www.motortrend.com/roadtests/.../overview.html
Old Jul 9, 2010 | 09:51 PM
  #28
jeffrudy's Avatar
there are probably better solutions to lower under hood temps.
wrapping the exhaust manifold would probably lower temps just as much as a hood vent.
the Humvees were designed to use that type of hood as a compliment to radiator and cooling setup specific to that vehicle. kinda of like the saudi grill wont lower temps to much by itself but its the actual system that improves airflow.
Old Jul 23, 2010 | 12:05 AM
  #29
Raw's Avatar
Raw
6th Gear
Great project! Please update post with pics. I would like to see how well this works out.
Old Apr 5, 2011 | 05:45 PM
  #30
pt2179's Avatar
4th Gear
Default Universal hood/side engine bay vents
I don't have any issues, just bought a really nice and clean 99 disco II. I've been doing my research since the beginning of time on these things (big brother had a LE RR) So I've decided to check into avoiding the head gasket failure issue. Jeep off roaders do it. After all, if you look into any of LR's history, you'll find out they're actually jeeps. Found this to be one of the better alternatives to cooling the whole engine bay. Also good for on/off roaders, and not badly priced either. Going to get some for my Disco II and paint them the color of the truck. Well, enough said here is the link.
RunCool Real Heat-Escape Hood and Side Louvers
99 Disco II
124,000 miles and clean
But I'm a USA Veteran, Hoo Rah
