Handwritten numbers in cylinder heads
Hi all,
im working on Head gasket job on my 2004 D2, im a noob, it’s my first one. I bought this D2 with clean carfax and 60k miles, is in pretty good condition. I drove it for around 2000 miles and never overheated but noticed small coolant leak in the front side of the engine right where the block and heads meet, and a valve cover gasket leak so I decided to adventure into a full HG job.
When I pulled the Cylinder heads I noticed that had handwritten marks on them with what seems to be a number 8 in one and number 22 in the other (see pics). Does anyone knows what these numbers mean?
It looks as though you might be working on cleaning those heads up yourself. Don't bother.
The general (strong) consensus is that whenever you do a HG job, heads should be professionally worked to insure a perfectly flat mating surface. A valve job is generally part of the job as well. A machine shop will dip them removing all carbon and they will be like new.
For both my P38 and D2 I had the heads machined at a shop, but I didn’t have the valves done (both engines only around 150,000 km). If I do another one and have the time, I want to try to resurface it myself. I think I could do as good a job. I don’t regret not having the valves done on these relatively low mileage engines.
As RMT says, a good thick glass plate with sandpaper. I’m interested in how you do the 3 angle valve seats without a machine. Many years ago I worked at a light aircraft engine overhaul shop where we did very good 3 angle grinds, but we had all the equipment. I also have no trouble believing you do a better job than any automotive machine shop.
