Hard to put gas into tank....
Ok, if you have made it this far, then you are curious about the topic.
I have a problem with filling up the gas tank. I get about 3 to 4 gallons into her and then it acts like the tank cannot hold anymore gas, and shuts the pump off. Yet, knowing that I still have a ways to go.
Can anyone tell me whats going on?
I have the feeling that it has something to do with the fuel canistor on the right fender well..
Welcome any and all comments.
John
John
I have ran accross the same issue a couple of times, mostly the Sams Club (Cheap premium...) down the street from work. Which I usually lift the nozzle out about a inch to help it vent, which the guy at the place says the pumps always do that. Which most other gas stations I dont have issues.
I've had this problem twice, at 2 different stations. The first time I dismissed it as an issue with the high-velocity pump, but the 2nd time was at a station I've patronized before and without trouble. I did fill the truck up at least once (maybe twice) between these two instances without any issue.
So, I'm not sure what's going on. But, it's time for gas again...
