Hard Starting on occasion
Old 02-15-2009 | 10:59 AM
Air temp has nothing to do with this problem, that valve is failing and you will be needing a new pump, sooner then later.
Ok, this will solve your problem, when ever you start the truck, BEFORE you try and start it turn the key "ON" and wait a few seconds, then start the engine.
Your fuel pump just needs to have time to get fuel up to the fuel rail.
Eventually you will need a new fuel pump, but wait until it gives you huge fits.
This may take a year or more, it may happen next week.
But when you do need a new fuel pump it is a easy DIY job.
Old 02-15-2009 | 01:27 PM
ljdiscovery's Avatar
As always Gentlemen, thank you bery much. I will start searching for for the fuel pump replacement threads. I did one on my Silverado last summer, pain in the tail and expensive (oem pump $550). Ended up just pulling the bed off of the truck, easier than dropping the fuel tank. Again, thanks much. Phil
Old 02-15-2009 | 01:40 PM
First place to start and look, http://www.roverconnection.com/
Old 02-15-2009 | 04:10 PM
On a Rover there is a access panel in the cargo floor, roll up the carpet, open the hatch, remove the fuel pump.
30 mins and shes back on the road.
Old 02-15-2009 | 08:56 PM
bowser881's Avatar
I was having a starting problem similar to yours a few months ago replaced the fuel pump and now it starts great... i found the fuel pump on www.drivewire.com for $240
kosho
12-29-2010 07:24 PM
RROJ
08-20-2010 10:07 AM
tover
09-20-2005 11:57 PM
mike
09-10-2005 06:30 PM
devildogrover
12-24-2004 04:48 AM
Quick Reply: Hard Starting on occasion
