Hawkeye Diagnostic
Old Jan 27, 2013 | 06:24 AM
chavhater's Avatar
From: at the side of the road wondering if I own the only Disco that doesn't like getting dirty
Default Hawkeye Diagnostic
Hi Guys
When using the Hawkeye, can i take it as read that the fault code P4114 Shuttle valve failure is the problem to my three Amigos.
Old Jan 27, 2013 | 07:07 AM
blamo's Avatar
If you clear it does it come back ? If it does its that .
Old Jan 27, 2013 | 09:39 AM
ZGPhoto's Avatar
Short answer, yes.
Old Jan 28, 2013 | 02:22 AM
chavhater's Avatar
Question Hawkeye
Thanks Guys I'm stuck in snow & -10c temperatures without a garage & not able to do the repairs until the spring, but this is the time that i need a four wheel drive vehicle. I was hoping to find a landrover garage which is proving difficult & purchased the Hawkeye so that i guide a prospective garage to the problem, without them going through a trial and error scenario as this is an intermittent fault, ive already tried two auto electricians prior to buying the Hawkeye who readily brought out there computers & deleted the fault code but that obviously dosen't cure the problem. ( because they have a computer their all experts)
Old Jan 28, 2013 | 07:16 AM
drowssap's Avatar
you have a 4114 shuttle valve failure code and your Hawkeye will not clear it, is that your problem? or it keeps coming back?
Old Jan 29, 2013 | 06:09 AM
chavhater's Avatar
Default Drowssap
Hi Drowssap thank you; yes the Hawkeye does clear the 4114 fault code, and when the three Amigos appear. The fault come's back with:
Fault 4114 Historical, Electrically Supervision, I dont meen to be a donut but ive read on the forum that the three Amigos can be caused by a number of Issues, manely the wheel sensors so i wasn,t sure how reliable the Hawkeye is compared to perhaps Land Rover Test Equipment.
Old Jan 29, 2013 | 08:44 AM
drowssap's Avatar
you need to install a shuttle valave repair kit and i would replace the o-rings as well.
the shuttle valave repair kit can be bought several place on line including ebay, the o-ring can only be sourced from one place if i remember correctly, i sure someone will jump in and tell you where.
you should also read this https://landroverforums.com/forum/di...s-fault-26847/
Old Jan 29, 2013 | 08:48 AM
mongosd2's Avatar
The Hawkeye is just reading codes, it really not any different than the Testbook, just is limited to what it can program...so to answer your question, like drowssap said, it's a shuttle valve issue
Old Jan 29, 2013 | 08:51 AM
drowssap's Avatar
check the last post on this page
https://landroverforums.com/forum/di...gs-ouch-56265/
Old Jan 29, 2013 | 09:49 AM
MoShadeTree's Avatar
I was getting the same error code, the amigos would randomly come and go but always the same code. I removed and tested the shuttle valve and it tested okay so I just did the bypass and I have been amigo free for about four months.
