hazard lights when hitting a hard bump
Old Mar 29, 2010 | 06:23 PM
discoxd's Avatar
Default hazard lights when hitting a hard bump
so my hazard lights come on whenever i hit a hard bump in the road in my D1 and the only way to get them to go off is to turn the truck off and then back on... what do i cut/unplug/burn/shoot to make this stop happening... it is the most irritating thing in the world to me... it happens sometimes like 2 or 4 times a day depending on where i am going... its killin me
Old Mar 29, 2010 | 06:36 PM
gsd2004's Avatar
My 98 Disco used to do that. However I never bothered to pay someone to look at it. Sorry!
Old Mar 29, 2010 | 07:35 PM
okdiscoguy's Avatar
Pretty sure it is your inertia switch. Under the hood, little button by the washer reservoir. If it trips a little, it will flash hazards. If it trips hard, it cuts the fuel pump. Cut it out and you will loose the safety cutout for the pump.
Old Mar 29, 2010 | 09:53 PM
oljohnboy's Avatar
Mine does it too, but it has to be a hard hit. Doesn't happen often enough to try ti fix. Nice to see that I'm not alone on that one, it really concerned me when it first happened!
Old Mar 31, 2010 | 06:51 PM
discoxd's Avatar
i dont care ab no stinkin safety mechanisms... did i mention when this happens i dont even stop anymore, no sir, throw that bad boy in neutral, cut the ignition, start her back up, match the revs and back in drive she goes
Old Mar 31, 2010 | 07:59 PM
Originally Posted by discoxd
i dont care ab no stinkin safety mechanisms... Did i mention when this happens i dont even stop anymore, no sir, throw that bad boy in neutral, cut the ignition, start her back up, match the revs and back in drive she goes
:d nice!!! :d
Old May 21, 2010 | 12:17 PM
batiscan's Avatar
It is an inertia switch but in the ECU: see owner manual p17 in RAVE and p805 of the workshop manual:
Mine went on after going over a rough railroad crossing. You can hear the ticking in the ECU box. If it happens to easily, one may want to check if the ECU is still well secured.
Attached Thumbnails hazard lights when hitting a hard bump-inertia-ownman.jpg   hazard lights when hitting a hard bump-inertia-wsman.jpg
CANAMDiscovery
Apr 2, 2012 04:20 PM
meltdowndave
Jan 3, 2010 10:28 AM
red rover 99
Oct 1, 2009 10:42 AM
darkside
Aug 22, 2007 04:06 PM
thawk78
Aug 18, 2007 12:44 PM
