Vibreation when hitting bump
Old Aug 17, 2007 | 07:14 PM
thawk78's Avatar
5th Gear
Default Vibreation when hitting bump
Hi, I need HELP!! "subject matter expert advise" I'm still haveing problems w/my 99 rr hse 4.6, when on the high-way @ normal speed and the RR hits a bump or an uneven pavement it starts to vibreate and wobbling. I press on the brakes and control the steering and its back to normal.
I replaced the front shocks, new bags last yr. suspension is tight and all torques check & lube, there seems to be minor rubber worn from the stabilizer links. Wheels balance, alignment done.
could it be the vibreation is due to the change in hight while driving (standard to high-way mode)? I'm want to correct the problem before I sell it. (its giving me alot of gray hair)
Please help[]
Old Aug 18, 2007 | 08:30 AM
Default RE: Vibreation when hitting bump
How long has it been since you rotated your tires for wear and replaced your steering stabilizer which if it has over 50,000 miles on it is shot?
Old Aug 18, 2007 | 10:46 AM
thawk78's Avatar
5th Gear
Thanks for the info, I have replaced the damper last week, also the tire where rotated and balance. Could it be the worm gear?
r/ed
Old Aug 18, 2007 | 12:44 PM
Possible steering gear wear, may want to look at the adjustment there and also look at the steering shaft from the steering wheel down to the gear box.
I can't remember, do you have swivel joints on your truck or CV joints?
CANAMDiscovery
Apr 2, 2012 04:20 PM
discoxd
May 21, 2010 12:17 PM
red rover 99
Oct 1, 2009 10:42 AM
feitinger
Jan 27, 2009 02:43 PM
sirbobdmw
Aug 5, 2008 01:58 PM
