head bolts stretch or not?
Old Apr 21, 2012 | 01:13 PM
arjoerover's Avatar
7th Gear
Default head bolts stretch or not?
Blown gasket on d2 w 130 miles.
Old Apr 21, 2012 | 01:21 PM
Yes. You must use new ones.
Old Apr 21, 2012 | 03:41 PM
arjoerover's Avatar
7th Gear
Yea going to buy new. Trying to decide between stretch bolts and non stretch? if anyone has used non stretch please post.
Old Apr 21, 2012 | 05:16 PM
jfall's Avatar
The kit you get with the headgasket should have new head bolts.
They stretch.
You torque them to 15 foot pounds in order.
Then 90 degrees all in order.
Put a paint strip on the bolts before beginning.
Use the paint stripe to figure out how far you have turned the bolts.
I have a tightening chart on
1997 Land Rover replace catalytic converter and head gaskets
It is a .pdf file.
DO NOT tighten a bolt at a time with all three steps.
You do ALL the bolts in a certain order. then repeat then repeat.
Old Apr 21, 2012 | 05:25 PM
buick215's Avatar
Like everyone else has said, use new bolts because the old ones are stretched.
Old Apr 21, 2012 | 05:28 PM
What difference does it make?
Head bolts are cheap.
Old Apr 21, 2012 | 05:35 PM
arjoerover's Avatar
7th Gear
Thinking about using tru torque bolts arp and non composite gaskets. Need this gasket job to last longer than 50k.
Old Apr 21, 2012 | 06:02 PM
Jake1996D1's Avatar
........ Why have you decided that it's better to go that route? Have you done a head gasket job on your truck before? If not the first ones lasted 130k so why do you think the second job wont last? It's all in how the heads are machines, what condition your block is in and proper torquing..
Old Apr 21, 2012 | 06:17 PM
arjoerover's Avatar
7th Gear
On 2nd set of gaskets. Not sure about bolts that stretch. performance motors use torque bolts 80 to 90 ft lbs.
Old Apr 21, 2012 | 06:21 PM
These are not performance motors.
If you over tighten them you run the risk of ripping holes into the block.
The HUMVEE head bolts are stretch and set at 25 ft lbs.
