head bolts stretch or not?
Old Apr 21, 2012 | 06:48 PM
buick215's Avatar
These engines are all aluminum: block, heads, oil pan, intake manifold, and valve covers. You do not want to over torque anything.
Old Apr 21, 2012 | 08:38 PM
arjoerover's Avatar
7th Gear
Going with non stretch bolts from napa. Loose to much torque with stretch bolts.
Old Apr 21, 2012 | 08:59 PM
NoBama316's Avatar
Why did you even waste your time on here then?
Old Apr 21, 2012 | 09:59 PM
arjoerover's Avatar
7th Gear
Wanting pros and cons. To
make a good decision..thanks
Old Apr 21, 2012 | 10:17 PM
HLC Fab's Avatar
ARP head studs aren't much more than the replacement stretch bolts and will apply the torque more evenly. These with the non-composite gaskets work great and if you do have an issue down the road with something and have to remove the heads you can reuse them.
Old Apr 22, 2012 | 06:33 AM
vandev's Avatar
Default Ditto
Ditto...Have them on one of my LR's.. Yes... I have more than one...I am a idiot and haven't learned my lesson...
Old Apr 23, 2012 | 05:03 PM
arjoerover's Avatar
7th Gear
Who did u guys order arp bolts from? K series studs?
Old Aug 21, 2012 | 03:58 AM
Racer X's Avatar
Just to bump this, does anyone have suggestions on which ARP studs to use, and the torque spec/ stages?
Old Aug 21, 2012 | 05:24 AM
drowssap's Avatar
ARP make a stud kit specically for LR.
Old Aug 21, 2012 | 06:57 AM
Racer X's Avatar
Yup, just found it. Just one more question.
- Some say torque to the full ARP recommended 80ft.lb. in increments, some say not to go all the way to 80ft.lb. for fear of pulling the threads from the block. Does anyone have any experience to this end?
