Head gasket job Questions
Old Apr 2, 2018 | 01:47 PM
Sixpack577's Avatar
I think you NEED the tornado ecu flash.
That way, you can tell us if it's any good, before we spend our money, lol.
Old Apr 2, 2018 | 02:26 PM
CollieRover's Avatar
I think it is probably money more well spent than gas flowing the heads. I was in for a few hundred on that job, but not $600. In the future I may go with new RPI Engineering cylinder heads if I feel the need.
Old Apr 2, 2018 | 02:50 PM
Sixpack577's Avatar
A good ecu flash has the potential to give similiar gains to port and bowl work on heads.
Ballpark 15-20 hp gains are possible with either.
On a Land Rover, who knows.
With an ecu flash, an extra mpg, or actual noticeable power increase is always hoped for, but not always achieved.
Which is why You should drink the koolaide first.
Tell us if it's any good.
Old Apr 2, 2018 | 03:12 PM
What sockets is everyone using to get the head bolts off? Do I need a set of the 6 point long sockets? Should they be impact?
Old Apr 2, 2018 | 03:17 PM
Saturnine's Avatar
I don't think you need the long 12pt socket -- you arent removing a nut off of a long threaded stud afterall.
Old Apr 2, 2018 | 03:21 PM
jamestfl's Avatar
Can you point me towards the injector rebuild kit?
used one of those Ebay kits with filters and o rings. Maybe give one of those recon sets a try, prices aren't that high, wish I would have seen that when doing mine.
Sixpack577's Avatar
A shallow, swivel (I think 16mm) socket makes it easy to get the 2 rear, lower head bolts out.
A regular socket and u-joint together are too long.
There's not alot of room at the firewall.
Old Apr 2, 2018 | 03:23 PM
jamestfl's Avatar
What sockets is everyone using to get the head bolts off? Do I need a set of the 12 point long sockets? Should they be impact?
used a HF swivel impact set. Worth the small investment.
Old Apr 2, 2018 | 03:24 PM
Sixpack577's Avatar
^This
And I will post a link to the refurbished stock injectors.
Let me find it again
Old Apr 2, 2018 | 03:26 PM
jamestfl's Avatar
IIRC, with a 1/2 ratchet and cheater pipe.
