Head gasket job Questions
Old Jun 5, 2018 | 09:51 AM
  #191
CollieRover's Avatar
Originally Posted by Jeff Blake
If the thermostat wasn't opening, your temps would be a lot higher than 204
that’s the old one. New one is opening. I just wanted to update that a thermostat that opens in a pot may not open in the car.
Old Jun 5, 2018 | 10:03 AM
  #192
Saturnine's Avatar
I feel like mine was doing that as well.
Old Jun 5, 2018 | 10:49 AM
  #193
Annoying.
Old Jun 5, 2018 | 04:50 PM
  #194
shanechevelle's Avatar
It will...its just that the temps at your sensor arent the same at the thermostat yet.
When you boil in water the temps are the temps...
With your car, your reading the sensor temp...it may have not gotten quite that hot there yet.
People are getting too scared to let their engine warm up.
My rover doesnt go over 206.6 idling. It took a 1/2 hour yesterday for the fan to kick on.
Old Jun 5, 2018 | 05:54 PM
  #195
she was at 209-211 for 30 minutes on my initial start up. So it was not going to open IMO. The heater on blast held 209, thermostat closed.
Old Jun 6, 2018 | 06:01 AM
  #196
That was open. If your stat wasnt open it would keep going.
You have/had and air pocket.
Old Jun 6, 2018 | 06:05 AM
  #197
If your stat is closed....the temp keeps rising. If it settles somewhere like 211, it's because there's air in the system and you've replaced coolant with air.
When you overheat it's because the stat is closed OR too much air has gotten into the system.
A closed stat wont sit there for 30 minutes and not raise the temp. At least in my 30 years in a radiator rebuild shop have I ever seen it.
Old Jun 6, 2018 | 07:56 AM
  #198
Maybe it partially opened, but I can tell you, the system is completely different with the new stat. The heater was also on full blast dissipating heat, and there was no drop in temp driving.
Old Jun 6, 2018 | 09:19 PM
  #199
Saturnine's Avatar
Old Aug 15, 2018 | 01:38 PM
  #200
Well guys. I feel sick.
I just got under the Rover to check and make sure everything is ok with the Crank Position sensor due to a no start issue, and lo and behold. The Driver's Side Head gasket is leaking oil back by cylinders 5 and 7.
I am not sure what to do to be honest.
