head gasket-pictures of spark plugs
Old 05-20-2022 | 10:19 AM
Gnomadf's Avatar
Default head gasket-pictures of spark plugs
So I thought I had the head gaskets sealed up but I revved up the engine and got a cloud of steam that would have made James Bond proud, decided to pull the plugs and see if any looked particularly steam cleaned as when you have a HG failure.
First photo is the passenger side. #2 looks suspiciously clean, especially compare to 6 and 8. Not sure what's going on there, but I have idled it more than driven it.
Second photo is drivers side. #1 looks dirty but the rest look like I would expect.
Cold dry compression test gives me 170 to 180 across all cylinders.
Or, given that I'm getting pretty decent compression, am i looking at a cracked liner or block?
All plugs were replaced along with the head gaskets.
I'm hoping I can get away with replacing just the passenger side, as I have 1 HG and 1 sides worth of bolts, I had a bolt pull the threads on the second 90' torquing and it was just as cheap to get a whole set of bolts and HG rather than piece them together. I also have some helicoils left after adressing that bad thread.
Old 05-20-2022 | 12:21 PM
JohnZo's Avatar
Well, looks like oil (black shiny plugs). I suspect the valve stem seals, especially since your compression is very good.
Maybe try some stop leak/seal conditioner. Or maybe replace the seals without removing the heads, at least make sure they are seated properly if you already changed them. That will be easier than replacing the head gasket. Even easier is using plugs with a hotter heat range, then topping up the oil as needed.
Gnomadf (05-20-2022)
Old 05-20-2022 | 01:18 PM
Alex_M's Avatar
How long did you run the motor after doing your head gaskets? It's common to have a bit of smoke on first start if oil or something got in a cylinder.
Old 05-20-2022 | 01:29 PM
Gnomadf's Avatar
I'm well past that point. It's been on the road a few times on short trips, gone through some cooling system bleed cycles, there shouldn't be leftover oil in it by now. I did rub some on the cylinder walls before putting the heads on so it wouldn't start running totally dry.
I never really thought about the oil seals though. My cloud wasn't oil, was defintiely steam. It doesn't smell of oil and dissapates quickly.
Old 05-20-2022 | 01:33 PM
Richard Gallant's Avatar
@Gnomadf I have to ask is it humid and cold there, could you just be seeing exhaust condensation burn off. Normally white from a head gasket leak does not go away and is very thick white.
Old 05-20-2022 | 03:36 PM
Gnomadf's Avatar
This is more than the normal exhaust condensation. Yeah it was cool that day, but this is really more than that-and under the pipe there was some carbon as if I'd done the water torture or a light course of seafoam.
So-is it possible that my throttle body heater is lightly leaking to the inside? Drawing in some coolant and burning it that way?
Man I am so up and down with this stupid thing! I really only need it until my Bronco comes in....but that could be a while.
Old 05-20-2022 | 04:41 PM
@Gnomadf Throttle body can only leak externally so that is not the issue
LR03NJ
11-16-2016 11:11 AM
kevinocall
04-10-2014 01:33 PM
slabrat
04-25-2013 09:38 AM
landover
12-14-2010 10:42 PM
SDinDS
08-23-2010 09:55 PM
Quick Reply: head gasket-pictures of spark plugs
