Head Gasket question?
Old Jun 21, 2010 | 12:09 PM
tigertrakstar1's Avatar
Default Head Gasket question?
I have a 96 Discovery with about 151,000 miles on it. Yesterday while drive at various speeds the truck would seem to act like it wasn't getting gas for about a second then would jump back to the normal speed, this happened repeatedly. For example if I was going 50, it would drop to 45 or so, and this just kept on until I drove it straight to my mechanic. Could this be due to headgasket not maintaining pressure? Or could it be a loose fuel-injector? My truck usually takes a few seconds to turn over, and there is a smell of raw gas in the air when starting. Any suggestions would be greatly appreciated.
Mike in S.C.
Old Jun 21, 2010 | 01:53 PM
Default update
Mechanic just called, said all I needed was a fuel injection flush.
Old Jun 21, 2010 | 04:54 PM
Don't buy it, that is just a quick way to make a few buck and not fix anything.
Are there any fault codes, when was it last tuned including wires and a fuel filter?
Old Jun 21, 2010 | 05:08 PM
Your VSS (vehicle speed sensor) is bad.
You do NOT need your injectors cleaned!!!
You can replace this yourself is you have basic tools.
www.discoweb.org has a tech section with a write up on how to replace it.
http://www.roverparts.com/Parts/YBE100540G.cfm
Old Jun 22, 2010 | 07:15 AM
Default tune up
I last had a tune-up last week, new sparks and wires the whole deal.
Old Jun 22, 2010 | 07:57 AM
Who's plugs and wires?
Spike is probably right on the VSS.
Old Jun 22, 2010 | 11:43 AM
Default tune up
Magnecor wires, and some idiot put champion sparks in there, replaced those with the plugs the LR dealer recommended.
Old Jun 22, 2010 | 11:45 AM
also fuel pump was replaced about 9 months ago, and the fuel filter is fine as well
Old Jun 22, 2010 | 12:24 PM
yloDiscoII's Avatar
You should be good with Champion plugs. There's a been a few folks reporting issues with the higher end plugs (specifically +4's) and DI's. I believe Champion is what Rover puts in there at the factory?? Someone correct me if I'm off my rocker...
Old Jun 22, 2010 | 01:09 PM
Default Spike
Is the VSS part of the abs or the transmission?
