Heading to mountains, 15W-40 T5 oil OK?
Hey guys im heading up to the mountains and it's going to get ~18deg F in the lowest at night. Probably 20-25 in the morning.
I am running Rotella T5 15W-40 because I live in a warm climate. Only going to be in the mountains for a couple days. Should I change the oil to a thinner viscosity?
Thanks,
Thanks,
This chart only shows the oil's rated temp ranges, meaning the temperatures where they are inside their rated weight. It doesn't take into account each individual manufacturer's engine tolerances.
I still say that 15w40 is the perfect weight for warmer climates, but I won't use it under 20* (for extended periods) because of the clattering I've heard my engine make with 15w40 under that temp.
I'm glad there is finally an oil thread! This is valuable information. Nothing like this has ever been discussed before, especially on the internet. *(runs, ducks, and hides)*
I kid. I prefer 5w/40 myself. Rotella T6. 15w/40 is fine, but I just don't like it in sub freezing climates. Cheers!
