Headlight condensation
Old Apr 16, 2008 | 04:00 PM
TOAD's Avatar
Default Headlight condensation
Anyone else had problems with headlight condensation? My passengerside has some in it and I don't want to spend $475 dollars for a new unit. any ideas??
Old Apr 16, 2008 | 04:52 PM
Default RE: Headlight condensation
Year and model would help, do your lights have drain tubes?
Old Apr 16, 2008 | 04:59 PM
My old FedEx E-250 had the same problem with the front turn signal's, they were full of water when I got the van, a small drill bit and I put two holes in the bottom, one on each sideand one in the middle on the top, water drained out and the condensation went away after a couple of weeks in the hot summer sun.
Old Apr 16, 2008 | 05:13 PM
TOAD's Avatar
Hey sorry about that. It is a 2003 Discovery SE. I don't recollect if it has drain tubes or not. I believe it is sealed. I just bought protector film to lengthen the life of the units and put them on today but they shouldn't have anything to do with condensation that I've had for about a month now.
Old Apr 16, 2008 | 05:32 PM
tee51397's Avatar
Yup, I get condensation. '03 also. I havn't investigated a fix yet but I assume it won't be covered under warranty.....even if it is supposed to be covered under warranty. You know how that goes.
Old Apr 17, 2008 | 06:48 AM
99XJ's Avatar
I had the same problem with mine just after I picked her up. Good News, it is covered under warranty (if you're still in warranty).
Old Apr 17, 2008 | 08:52 AM
As Spike mentioned, if you don't have drain tubes, a small hole drilled in the bottom of the housing will take care of it.
Old Apr 17, 2008 | 12:18 PM
tee51397's Avatar
ORIGINAL: 99XJ
Do you recall if they replaced the whole assembly or if it was just a seal or the like. I ask because I would like to know how others have had the problem handled when the svc. dept tells me LR isn't going to cover it. Perhaps a bit cynical but I don't feel like the dealer really pushes the warranty people very much. Thanks!
-T-
Old Apr 17, 2008 | 02:15 PM
newdr's Avatar
I JUST STARTED TO SEE SOME CONDENSATION AFTER A MECHANIC REPLACED A BURNED OUT BULB.
D2 2003, 85K
Old Apr 17, 2008 | 08:14 PM
If you are getting condensation after buld replacement it is most likely the bulb isint seated properly and is letting moisture in from behind the bulb.
